Clutch issues!!!!
Clutch issues!!!!
Ok so my clutch is either bad or just need fluid?! I noticed the resoviour was completly dry which is not good so I put fluid in and still the clutch does go in gear!! Anyone shed some light on the subject
the fluid went somewhere so you probably have a leak at the master or slave, likely the slave. Two 13mm nuts hold the slave on the side of the tranny, pull it off and see of there's fluid coming out of the boot.
