Another LSx in my nova.....
WEll after my car sitting for a lil over a year i dealed into a new drivetrain for it.
Details are as follows.
07 6 liter with 7k miles, has L92's on it.
Liberty Faceplatted T56 Spec 3+ clutch, Spec billet steel flywheel.
9" rear Stange 31 spline Pro race axles, ??? gears, detroit locker.
XXR 18x8.5's and 18x9.5's 275/40R18 front 295/35/18 BFG brag radial rear
Coil overs on all four corners
Custom Torque arm rear suspension
Mini tubbed
Work is coming along slowly but i should have it together and driving in the next 2 months. Heres a few pics of the progress.
Mini tubbed
Just read thru that... Thanks for the link. I actually bought mine from Fitz98ta in that thread after his car got wrecked.
Can't wait to get to drive this thing.
Which mounts are those? I would like a set
Also how much did you trim off the truck pan to clear the steering linkage?
I have a ctsV pan but havnt decided which one i want to hack up for my swap.
Eric
Eric
I only shortened my pan height wise. It clears the steering stuff as the engine is farther back.. Ill get a picture of it when i go back out to the shop.
Those are very nice, indeed. Would you be willing to share the deminsions? I can make them. I will be using the truck intake for now as it shouldnt hurt much with boost. It would be great no to have to cut the oil pan, thats for sure. I would like the easy part to be getting the engine in so i can started on the hot pipes.
I am running 6 cyl springs in the front and had clearance enough for a SBC 7 qt pan. I was thinking id even have enough room for the truck pan.
Ordered my cam yesterday from texas speed. 229 236 .624 .615. Also ordered the rest of my gauges, mufflers shifter handle and a bunch of other odds and ends.
