Drag Racing Tech
relocated battery, now having trouble with alternator
Old 05-12-2010, 12:33 AM
enjoi355's Avatar
Default relocated battery, now having trouble with alternator
hey guys, i have a 94 formula with an lt1 and well like the title states, i relocated the battery to the trunk, but i am uncertain of how to run the cables...
i ran a cable from the battery to the distribution block (little red box)
then i ran two cables from the distribution block, one to the starter, and the other one to the alternator
i got this idea from here https://ls1tech.com/forums/drag-raci...-question.html
now the problem im having with this setup is that the alternator has gone crazy and screams really really loud
i got it rebuilt and still the same thing
i even swapped it out with a good one from my other car (95 z28 with an lt1) and same thing
the alternator gets extremely hot too, o and another wierd thing is that when i plug in that connection on the back, it screams, i unplug it, it goes away
would anyone ahve any idea wtf is wrong here
Old 05-12-2010, 07:32 AM
Old Geezer's Avatar
Alt is running WFO....Check the voltage.
Also, if you are doing the relo to take to the track, that setup will not pass tech.
Old 05-12-2010, 09:51 AM
InsaneAuto86's Avatar
You need to use this diagram for it to function correctly and be legal:
Old 05-12-2010, 11:44 AM
enjoi355's Avatar
our track doesnt really care, lol
but what is WFO mean??
ooo and thanks for the diagram
Old 05-12-2010, 12:14 PM
enjoi355's Avatar
o and what can cause the alternator to run WFO
Old 05-13-2010, 12:17 PM
enjoi355's Avatar
anyone??
Old 05-13-2010, 01:26 PM
spoonraker's Avatar
WFO = wide ******* open
Old 05-13-2010, 01:30 PM
1lejohn's Avatar
The wire size from the batt. might be to small, bad ground,loose connection,bad alt. The diagram above works but will reset the computer when you turn it off. Killing the fuel pump is a better way for street driven cars. You still want to dissconnect the main cable going to the starter with the switch. This will also pass tech.
Old 05-14-2010, 02:51 AM
enjoi355's Avatar
it sounds like i have to hunt this problem down.... alright thanks guys
