4l60e AN transmission fittings
Old 05-16-2010, 12:06 AM
elias_799's Avatar
Default 4l60e AN transmission fittings
i want to make braided lines for my transmission cooler and route the in to the fender, so they are out of the way
so what i adapter will i need to go from the transmission to -6 line ?
some say i will need 1/4npt to -6, is that right ?
also what sort of pressure will those lines see ?
Old 05-16-2010, 12:17 AM
7th Darkness's Avatar
Yes you need 1/4 to -6 fittings.
Pressure will remain the same for the most part.
Old 05-16-2010, 08:54 AM
01ssreda4's Avatar
Do not buy 1/4 npt, thats not the same kind of thread the trans has cut in it. Buy a correct fitting like this: 1/4 NPS straight cut threads.
http://cgi.ebay.com/ebaymotors/8-tra...Q5fCarQ5fParts
Old 05-16-2010, 09:49 AM
Both NPT and NPS have the same thread angle, shape, and pitch. However, NPT threads are tapered and NPS threads are straight.
Which one to use is argued millions time over, Both work. I am using NPT in mine and have been for a while, no problems.
But they are actually NPS.
Found this picture, NPT on the left screwing into a NPS connector, NPS on the right... both screwed in hand tight, equal resistance. you can see the difference, but its up to you.
The following users liked this post:
n2xlr8n66 (03-04-2022)
Old 05-16-2010, 11:06 AM
elias_799's Avatar
both upper and lower hole in the tranny require the same fitting ?
Old 05-16-2010, 02:04 PM
Greaseymec's Avatar
I used 1/4 NPT to -6 AN 45deg angle fittings with no issues. Max line pressure is also a non issue. Tranny might see 230 psi max if someone has done some work to the unit. Same fitting for both.
Mec
Old 05-16-2010, 02:10 PM
elias_799's Avatar
if i just use a straight adapter with 90 degree -6 fitting it will not clear ?
Old 05-16-2010, 05:55 PM
I am using summit part number EAR-984006ERL, not sure about the 90, but obviously the 45 works from the post above. Same fitting.
Old 05-16-2010, 08:38 PM
01ssreda4's Avatar
Why would you buy an NPT fitting when an NPS is available. Makes no sense.
Old 05-16-2010, 09:12 PM
elias_799's Avatar
^^^i looked on summits website and they do not have it.
i am going to see if my supplier from Quebec can get them
Old 05-16-2010, 10:16 PM
ThreeHonks's Avatar
I want to use braided lines with my cooler as well. how hard are they actually to make in the first place?
Old 05-16-2010, 11:16 PM
elias_799's Avatar
^^^^ braided lines are very easy to make
Old 05-17-2010, 08:20 AM
ThreeHonks's Avatar
any writeups or instructions on how to do them?
Old 05-17-2010, 10:09 AM
Its no different from regular lines. Just cut the hose to length, put the little fancy clamps on the end if you choose and your done.
Old 05-17-2010, 11:43 AM
BlwnLs1GTO's Avatar
This should help you. If you have any questions let me know.
Hope nobody minds me posting another forum?
http://www.ls1gto.com/forums/showthr...=hose+fittings
Old 05-17-2010, 03:55 PM
ThreeHonks's Avatar
thanks a lot for that. Doesnt seem as bad as I thought. Its definately the "right" way to do it over using normal rubber lines
Old 05-17-2010, 09:05 PM
elias_799's Avatar
if a rubber line is rubbing on something it will get punctured eventually and tranny fluid is flammable. if ss braided line is rubbing on something, most likely will eat what ever it is rubbing on
Old 05-18-2010, 10:40 AM
Bill Bowling's Avatar
How much line should I order? It looks like Summit has everything you need. I am getting 2 straight adapters with 45 degree swivel hose ends. I thought 10 feet of braided line should be enought.
Part #PriceQtyTotal
Earl s Performance 804606ERL - Earl's Performance Swivel-Seal Hose Ends
View Image and Compare
Fitting, Hose End, Swivel-Seal, 45 Degree, -6 AN Hose to Female -6 AN, Aluminum, Red/Blue, Each
Part Number: EAR-804606ERL
Transaction
• $16.95
• $67.80
• Remove
Earl s Performance 961946ERL - Earl's Performance AN to NPT Adapter Fittings
Fitting, Power Steering, Inverted Flare, Tube, - 6 AN, 1/2 NPT, Steel, Zinc Plated, Each
Part Number: EAR-961946ERL
Transaction
• $8.95
• $17.90
• Remove
Earl s Performance 981606ERL - Earl's Performance AN to NPT Adapter Fittings
Fitting, Straight, -6 AN Male to 1/4 in. NPT Male, Aluminum, Blue Anodized, Each
Part Number: EAR-981606ERL
Transaction
• $2.95
• $5.90
• Remove
Summit Racing SUM-230610 - Summit Racing® Stainless Steel Hose
Hose, Braided Stainless Steel, -6 AN, 10 ft. Length, Each
Part Number: SUM-230610
Transaction
• $39.95
• $39.95
• Remove
Summit Racing SUM-900106 - Summit Racing® AN Line Wrenches
AN Wrench, Aluminum, Anodized, -6 AN, Each
Part Number: SUM-900106
Transaction
• $9.95
• $9.95
• Remove
Part Subtotal $141.50
Bill
Old 05-18-2010, 01:51 PM
Part #PriceQtyTotal
Transaction
• $16.95
• $67.80
• Remove
Transaction
• $8.95
• $17.90
• Remove
Transaction
• $2.95
• $5.90
• Remove
Transaction
• $39.95
• $39.95
• Remove
Transaction
• $9.95
• $9.95
• Remove
Bill
I just ordered all of the above. All to look good and keep this new trany kool.
Bill
Quick Reply: 4l60e AN transmission fittings
