LS1 into 95Z
Good idea ...Several write ups on this here.....just do a search "the merv" has some good info. Thats his username. Right off the top of my head u need K-member, rack and pinion, ls1 engine mounts, pcm, wiring harness.
You can swap the input shaft and use your trans... you will need an ls clutch setup though.
Although I feel the entire swap is retarded. Build them both and they will both produce great power. After all the ls cars I've raped with my baby cam only setup I would never consider switching. All I want is their coil packs
