Can't stand the sound!!!!!!
Old 05-26-2010, 07:45 PM
tg580's Avatar
Default Can't stand the sound!!!!!!
I have pacesetter longtubes and ORY with a Magnaflow muffler. It sounds good while idling or rapping the gas while in park but on the road under alittle throttle the damn thing resonates so bad it makes my teeth hurt. What to do?
Old 05-26-2010, 07:50 PM
mesterious's Avatar
Add cats.
Old 05-26-2010, 08:11 PM
HuggerOrangeZ's Avatar
I have the same set up and it doesn't resonate at all. Sounds good at idle, medium thorotle, and WOT.
Old 05-26-2010, 11:31 PM
D.Jones's Avatar
I have longtubes, ory, and magnaflow cat-back and it sounds good at any throttle position. what kind of merge are you running on your y-pipe? does one pipe slam into the other pipe or does it have a flowmaster merge style collector? I have a tsp ory and it has a good merge collector where both pipes meet side by side then merges together. A lot of people says that this style cuts down on the rasp. just something to consider.
Old 05-26-2010, 11:40 PM
Titanws6's Avatar
Put a flowmaster merge on or a bullet in the I pipe, this will help reduce the rasp. I did a FM merge, night and day diffrence.
Old 05-26-2010, 11:50 PM
odarabla's Avatar
or you can just do a true dual setup. That's what I did and there no rasp at all.
Old 05-27-2010, 05:38 AM
tg580's Avatar
What is a bullet? I have got to do something because it is abnoxiously loud and raspy. PAPAPAPAPAPAPAPAPAPAP. Any of you that have a flowmaster merge on theirs can you send me a picture so I can compare what I have? TG580@aol.com
Old 05-27-2010, 08:46 AM
evo462's Avatar
It's a cylindrical race style muffler that can be welded into the I pipe.
http://www.google.com/products?hl=en...ed=0CDAQrQQwAg
Old 05-27-2010, 09:05 AM
udienow's Avatar
this is the winner. Same story here regarding the flowmaster merge.
Old 05-27-2010, 01:48 PM
brian_rs/ss's Avatar
fm merge here. check the sig and my youtube account if you are real curious. also big diameter exhaust FTMFW.
Old 05-28-2010, 04:20 AM
TORCHD 02 TA's Avatar
Maybe it's just my exhaust. A FM merge didn't make a difference on my cars exhaust. Now when I added a bullet muffler (still had the FM Merge) in the I pipe, it kille d98% of my rasp
Old 05-28-2010, 05:26 AM
tg580's Avatar
When adding a bullet muffler do you still keep your original muffler and just add the bullet before it? Does this take away much horsepower? I need as much info as I can get because I need to make my changes soon. i'm going in for a dyno tune in 2 weeks.
Old 05-28-2010, 05:51 PM
tg580's Avatar
I am in need of a tune. It goes in for a dyno tune on the 15th of June. Could that have anything to do with it? In park or neutral when you rev it, it sounds fine. Under load it sounds like hammered dogsh!t. I am new to this so I am totally clueless here. It's so loud and resonates so bad I don't even want to drive it.
Old 05-28-2010, 10:16 PM
Titanws6's Avatar
Here is a link to some pics I took before/after I had the merge installed. They usually run about $50 for the merge. Now, I can't say it will take away 100% of your rasp, but, it does provide a much better merge over the Y you have now and this is where the rasp is coming from.
If you put a bullet in the I pipe, this may help too. I would recommend keeping your magnaflow catback with a bullet, if you just did a bullet, it would be extremely loud.....
I did see a gain in hp/tq from before and after the merge, granted my 1st set-up was crap, but I think if you did this mod before the tune, it will only add to the final result......Just my $.02
https://ls1tech.com/forums/generatio...erge-pics.html
Old 05-29-2010, 02:36 AM
the fm merge cuts down on turbulance wich will also reduce rasp. but since the fm merge brings the pipes together at an almost parallel angle the turbulance is almost non existant. also its pretty retarded IMO to join 2, 3" pipes into 1, 3" pipe. it's most definitely a choke point. at least go to a 3.5" i-pipe if not 4".
Old 05-29-2010, 04:35 AM
DoggyB22's Avatar
Just go open headers or a good true dual exhaust... Can't get any better haha
Old 05-29-2010, 11:31 AM
tg580's Avatar
This part is wierd. When I manually shift it the sound is not as bad. Can't understand that one. It is the worst between 2000-2500 under acceleration while the car is in drive. I'm scratching my head here.
Old 05-29-2010, 01:42 PM
duh. that just so happens to be the highest resonation point of your exhaust. and its made worse by the poor design of the y-pipe and the small diameter of the i-pipe and cat back. we've already told you how to fix it.
Old 05-30-2010, 09:53 AM
tg580's Avatar
Well excuse me Brian for not being as smart as you.
Old 05-30-2010, 01:44 PM
Titanws6's Avatar
I don't think by changin your driving habits or manually shifting will fix the issue. You are cammed with some really good flowing heads, but now your exhaust can't exit it smoothly enough. My rasp happened between 2-3k rpms too, under accelereation, but while crusing, no issues. I think Brian is just saying that there is no way around this...... you need to fix your Y pipe merge or get true duals. If you don't wanna get a FM Merge and have an exhaust shop fix it, look into TSPs new ORY design, it incorporates a FM style merge, and will probably help with your issue. You have 15 days till tune, better start ordering parts now.
