AFR 62cc head with .040 head gasket = 11:1 CR Right? LS1
Old 05-31-2010, 04:52 PM
transamman1234's Avatar
Default AFR 62cc head with .040 head gasket = 11:1 CR Right? LS1
Guess i was a little late calling AFR today, could not get through. Is this right? I have stock pistons. For an 02LS1. Is there a chart? I have never found one on here.
Old 05-31-2010, 05:36 PM
Unaffliated Racing's Avatar
11.15 with a zero deck. Here is a nice little calculator.
www.eaglerod.com
Old 05-31-2010, 05:38 PM
bore is 3.898
Old 05-31-2010, 05:48 PM
JimMueller's Avatar
I removed my original reply because I couldn't quickly find the typo. When I fixed the bore typo to 3.898, I get 11.35, which matches the calculator here: http://www.kb-silvolite.com/calc.php?action=comp
Old 05-31-2010, 06:02 PM
Reason is because, when i ordered my GM Head and Cam Install Kit I ordered it without the Head gaskets because AFR told me to go with .040 cometic? gasket for 11:1 and the speed shop did not have any in stock so i never got them. When I got my Install kit the guy ended putting in
GM# 12498544 Head Gaskets
and did not charge me for them (i checked)
So now Im putting this together in the garage thinking about using these head gaskets maybe.
I can't find any info on what CR I will get with this GM MLS head gasket on these afr 62cc heads (the 205's). Im not even sure what the thickness of the gasket is? Can anyone help? Could not get through to AFR today. Thanks...
Stock block deck height, stock pistons, stock everything down there.
Old 05-31-2010, 06:09 PM
Paint_It_Black's Avatar
It's 11.34 to 1.
3.898 bore
62cc chamber
.040 gasket
piston .007 out of the hole
3.910 gasket diameter
I used Pipemax for that calc.
Old 05-31-2010, 06:10 PM
I did not mind hearing 11:1, but i don't like hearing 11.15 to 11.35 going to be on a 96,000mi motor. Now im thinking my camshaft might start running into some P/V clearance issues. Comp Cams 222/224 .566/.568 lift. 112LSA. I was almost thinking 10.75 would be good to? Its not a race car. I drive it everyday in nice weather though.
Old 05-31-2010, 06:12 PM
www.eaglerod.com
If only the LS1 was a zero deck, you'd be right, but you're wrong.
Old 05-31-2010, 06:15 PM
With a stock gm mls gasket you drop from 11.34:1 to 11.0:1
Old 05-31-2010, 06:24 PM
Can anyone else help confirm this please
Genuine GM# 12498544 Head gaskets will make exactly 11:1 CR with these AFR 205's at 62cc's? I specifically asked AFR on the phone and he was all about the perfect 11:1 CR with that .040 gasket and 62cc head...
Thanks guys. Might end up putting here together tonight then...
Old 05-31-2010, 07:11 PM
Confirm it yourself.. http://www.kb-silvolite.com/calc.php?action=comp as was posted earlier since you prob don't have Pipemax.
Punch these in:
62
0
.051 (or .040 for cometics)
3.910
3.898
-.007
3.62
Old 06-01-2010, 12:59 AM
PAINT IT BLACK- Thank you very much! Much appreciated. Are you a Stones fan or does your name mean something else? Rock on.
Old 06-01-2010, 01:14 AM
Stones fan
Old 06-01-2010, 10:03 PM
SOMbitch's Avatar
Originally Posted by Paint_It_Black
Stones fan
Haha love the Stones ...Exile on Main St is prolly my favorite album
Old 10-07-2023, 06:03 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Running stock ecu?
Old 10-07-2023, 08:41 PM
Received 3,022 Likes on 2,353 Posts
Running stock ecu?
John- 13 year old thread....
Old 10-10-2023, 08:19 PM
LilJayV10's Avatar
BAAAM. my boy is on it!
The following users liked this post:
G Atsma (10-10-2023)
Quick Reply: AFR 62cc head with .040 head gasket = 11:1 CR Right? LS1
