TR6 spark plug gap
NGK recommends one heat range reduction for every 100 hp added. I have the setup in my signature and am running TR6 plugs with the gap as provided from the box. If you want a larger gap, the 2nd number (TR55 for example) provides the larger gap. In other words the only difference between TR5 and TR55 is the provided gap.
I am running them straight from the box and it runs great. I have had them out several times and they are clean and appear to be functioning properly.
11.9:1 here running the tr6 gapped at .035...also tick has done back to back dyno tests and this gap with the same plug gave the highest hp...
a straight tr55 is not cold enough when you start upping the compression...
485rwhp though a locked a4 here...
http://www.ngk.com/results_app.asp?AAIA=1432727
http://www.ngk.com/results_app.asp?AAIA=1433649
that is good an all but I checked all of mine and they were are around .040 out of the box tr6...I tightened them up to .035...
