LT1 Not Starting. .
LT1 Not Starting. .
I've been having a rough time trying to figure out whats going on with my car. It has had trouble starting for awhile but it always fired eventually. Now it won't start at all, it just continually cranks.
-The car IS getting spark, 3 cylinders were checked, spark on all three.
-The fuel pump is working, read 45psi with a fuel pressure guage.
-The fuel injectors were also checked with a test light while cranking on the car. They are all getting power.
-Thought the problem was the PCM, so I tried another one and the problem still persists.
I am open to any suggestions, this is very frustrating.
Try replacing the coil. It may have spark but it might not be strong enough to start. I had this issue on mine a few years ago and learned the hard way after I spent $400 on an opti I didn't need.
