Has anyone upgraded the plastic cup for the shifter?
Thanks for the pic. That's about it I guess. I could hear the pitch change slightly once it bottomed out as I was tapping it in and I couldn't feel a gap between the cup and the base. Not about to take it apart again. I can definitely feel a difference in the shifter. I was always amazed how easy it was to go from gear to gear and now the effort has gone up just a little and the cup was the only change. I test fit the new cup to the shifter before installing it and it felt fine. Anybody know what type of epoxy they used to hold the stock piece in? That's some bad *** glue.
[QUOTE=MeentSS02;13469641]This is how mine sits:
http://www.ls2.com/forums/showpost.p...69&postcount=2
It's a pain. You don't have much room to leverage anything. It doesn't have much of a lip to grab on. If you do get a grip, it will break off. I ended using a small pair of side cutters and snipped away it until there was about 2/3 left and then it finally released. Put a rag under the mechanism to catch any small pieces of plastic.
