How much is to much?
Old 06-18-2010, 07:32 AM
ta-stanger's Avatar
Default How much is to much?
My car uses around 1 qt. of oil between oil changes. No leaks, no smoking. I never had a car that uses oil but then I have never had a high horse power car either. My car has the full bolt-on's, cam and heads. Runs fine no issues!
Is there anything that might be messed up or is this not out of the norm?
Old 06-18-2010, 08:21 AM
fleetmgr's Avatar
Depends on how many miles you're running between changes. If you're doing 3000 mile changes, then I wouldn't get upset about it. If it's 1000 miles, then you've got a problem that should probably be looked at.
Have you checked for leaks? If it's leaking, most of them are too easy to fix to not do something about it.
Old 06-18-2010, 08:29 AM
ta-stanger's Avatar
No leaks ! I change every 3k
Old 06-18-2010, 08:33 AM
tording99Z28's Avatar
Yeah, its pretty common for them to use a quart or so for every 3K miles driven. I wouldn't be too concerned if its not smoking and running strong.
Old 06-18-2010, 11:40 AM
samson_420's Avatar
How many miles on the motor?
Most likely on start up and on fair to hard acceleration.
Old 06-18-2010, 11:47 AM
ta-stanger's Avatar
I got 15k on my baby!!:>)
Old 06-18-2010, 12:13 PM
samson_420's Avatar
WOW!
And you use a quart every 3k. ****, I use 1 quart in my DD and it has almost 230k.
Take a look at your PCV and breathers. Also take a look inside the intake, it might be pulling in oil through the instake manifold.
Old 06-18-2010, 12:23 PM
gyrene2003's Avatar
holy **** man, i thought i was low miles in 7x,xxx region, 15k, that sick man! yeah make sure ur not pullin oil throught he intake, but i wouldnt be to concerned about it!
Old 06-18-2010, 10:16 PM
223HAWK's Avatar
Its a GM motor they all use oil...
Old 06-18-2010, 10:19 PM
peterlawl84's Avatar
Do the LS6 PCv conversion
Old 06-18-2010, 10:55 PM
Carter Hays's Avatar
Gm specs 400-600 miles per quart. I have had three of these cars and all used some oil. It's the pcv design that is the culprit in most cases. Get a good dual catch can set up if it bothers you.
My dad still daily drives his 01 1sc stripper that he bought new, and from day 1 it used around 1/2 to a quart every 3000 miles. That car is stock and at 80k miles it still runs and drives like new... Don't worry.
Old 06-19-2010, 12:53 AM
samson_420's Avatar
That is a BS excuse we use to make ourselves feel better when our **** is fucked up.
My last(GM) car used 1 quart every 2k, my 98 uses none, what so ever. Ok, maybe a 1/4 every 3k.
