General Maintenance & Repairs - Vibration in the wheel!!
WS6 Rampage
06-24-2010, 09:19 PM
Random vibration in the wheel. Need some thoughts of what the issue is. The vibration in the steering wheel isn't limited to just the steering wheel. There is also a visual shutter in the wheels also. Only noticed while the car isn't moving. Noting noticable while car is in motion. Power steering fluid is at an appropriate level. No odd smells or sounds comming from the rack & pinion or pump. Steering wheel does not feel any more stiff than normal. Vibration isn't constant. It randomly pops in and out of vibrations while turning the steering wheel in both directions.
THOUGHTS?!
WS6 Rampage
06-26-2010, 03:23 PM
Bttt!
ULTIMATEORANGESS
06-26-2010, 04:45 PM
tires out of balance or wearing unevely perhaps.
Craig Gibbs
06-26-2010, 04:55 PM
im thinking tire rod.
doublea87
06-26-2010, 09:00 PM
check if the rack and pinion is tight and the bushings are good and in place
WS6 Rampage
06-27-2010, 03:28 AM
Tires only have 60 miles or so on them. Just did a motor build and threw the k-member and motor in last week. Maybe the alignment IS off.
WS6 Rampage
06-27-2010, 03:29 AM
Yea, already checked.
WS6 Rampage
07-04-2010, 02:52 PM
Bttt......
ls1 1990 VN
07-07-2010, 02:20 AM
Drive shaft!!!!!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
