Oil pan!
mann my Car and oil wreck! it leaks from the timing cover from the rear main seal and the oil pan!
if it was you car with this problem which of the 3 leaks you would fix first?
how much am i looking to get these leaks fix in a shop?
can anyone give me and estimate of what im looking forward to pay?
Disconnect the stock y-pipe, take off the starter, remover the motor mount thru-bolts, jack up the engine as high as possible, lower the bolts that hold the k-member in place, remove the oil pan bolts, hope to God you can get it out.
i have slightly skimmed through a few of this guys threads, is it safe for him to work underneath a car?
Most of the time, but I have seen some exceptions to this. Even A4's can need extra clearance when the engine/tranny is jacked up. Mine gave me so much hell (I'm an M6) that even when the k-member almost all the way out and the engine as high as possible it still took some hard pulling to remove it.
