98-02 rear end on 93-97
hey guys I am in need of a new rear end and i found a couple of them here locally for good price. I would like to know if a 98-02 rear end will fit my 95 lt1.
but if he runs drag rims there are some that will not clear ls1 brakes but will clear lt1. I dont know what it takes to swap e brake types but i know that if you plan on checking the rear gears (pulling the cover) its only like 10 minutes extra to swap backing plates
Do you have 3 or 4 channel abs? If you have 4 and the car you are getting the axle out of has 3 then you will need to grind a bit out of the flanges to clear plug for the ring pickups. If you have 3 and the other car has 4 then it won't have the center ring in between the carrier and the ring gear or the hole in the case for a sensor. Post more info, I've been through this.
Thanks for everyones comments iam really thankful for your help.
By the looks of it im getting a rear end of LT1 friday thanks.
One more qurestion since my car is a 95 with no traction control that makes it a 3 channel right....?????
NO ! Unless you're willing to put up with NO ABS !
https://ls1tech.com/forums/gears-axl...-3-w-pics.html
What broke on your old rear? You could use your old housing and gear set and keep abs if that's not what broke.
FYI - An easy way to know if you have 3 or 4 channel ABS is to take one of your back wheels and brake rotor off and see if you have a reluctor ring behind your axle flange. If you do then you have 4 channel and if not then you have 3.
