Poly Motor Mount Question
I just bought two of the energy suspension motor mounts (part number 3.1116G) and one side seems like it is too big for the metal shell. Are there two different part numbers that I should have gotten or what? I thought that (from what I had read) both sides would use the same size poly insert.
Thanks
Thanks
after posting this question I found this...http://www.amazon.com/Energy-Suspens.../dp/B000CNAXQ6 I feel a bit dumb now. lol I was just in a hurry when I was ordering I guess. So... buy this one, or shave down the one I have???
They are two different pieces for driver vs. passenger side.
http://www.jegs.com/i/Prothane/311/7...oductId=762286
They won't really fit in the clamshells at first, but when you crank down the nuts/bolts that they (should have) come with they'll snug right up.
http://www.amazon.com/Energy-Suspens...8382471&sr=1-1 this is the one I got for 1 side. It comes with zip ties, and says to put it in a vice and just tighten down the ties... do the zip ties sound like a good plan to you guys?
My energy suspension pieces said "zip ties" in the instructions too, but they actually came with nuts and bolts in the package. I definitely would not use zipties, although it's probably not a big deal since they get sandwiched between the k member and block anyway.
