Which is most likely to fail 1st
motor for sure. but like he said test the switch first its easier at least. Never seen one bad myself but maybe.
If you own an f body you have to be good at changing window motors, theres just no way around it. thats a huge piece of glass.
Window
Yea the radio and passenger window still work, of course i have the slow rolling paasenger window. The radio is aftermarket, not sure if that matters. As far as a replacement i know the stealership is rediculous, would you guys recommend one from napa or o'reily's?
edit: looks like they have motors for $27-$36
My moms trans am had a window motor go out under warranty. Under 36k miles/3 years
Its one of the most common f-body problems.
Ive only had 1 go out in the 38k miles i've had mine
