converting dbw to cable
Old 07-17-2010, 02:10 PM
jarias's Avatar
Default converting dbw to cable
Helloe everyone I am converting from 2001 corvette to camoro PCMs I need to know the wiring for the trottle body I have the correct pins from an old Harness I just need to plug them into my PPCM
Basicly I purchased the new 2001 camoro throttle body and removed my old dbw throttle body put the plugs are different I have the corect plugs but need to plug them into the pcm
ANy help would be appreciated
Old 07-17-2010, 02:19 PM
Pocket's Avatar
This should help
PM sent about the old DBW stuff
Old 07-17-2010, 05:41 PM
jarias's Avatar
Thank you exactly what i was looking for
Old 07-18-2010, 01:05 AM
Quickfrc's Avatar
is there a thread on how to do this swap?
Old 07-18-2010, 08:55 AM
Pocket's Avatar
Its not difficult. First determine if your PCM even supports the IAC. Red/Blue PCMs always do, blue/green sometimes
If it's compatible, depin the two serial wires that went from the TAC module to the PCM and add the 7 wires for the TPS/IAC. All the TAC module and pedal wiring can come out too
Flash in a DBC tune, swap the TB itself, set a cable bracket and you're done
The above diagram is only valid for 99+ red/blue PCMs. Green/blues changed pinouts slightly. This site has more specific info on the green/blue's
http://www.lt1swap.com/cable_conversion.htm
Old 07-18-2010, 01:36 PM
welldonecj7's Avatar
anyone have the part numbers for the plugs you will need for the TPS and IAC
Old 07-18-2010, 05:08 PM
Pocket's Avatar
They're pennies on the dollar from a JY or I can send you a pair. Ive got a ton
Old 10-30-2010, 10:58 AM
TurboGoKart's Avatar
For what it's worth, those pigtails can be had off of almost any GM car. Colors match up too. I grabbed mine off of a Northstar.
Quick Reply: converting dbw to cable
