Oil in coolant??
Oil in coolant??
I have about 200o miles on my new 408 stroker lq9 engine. i broke a rocker at about 1500 miles and ever since then it has been smoking on start up and using oil. Last night i found where the oil was going, the radiator. But as far as i can tell there is no coolant in the oil pan. Does anybody have any idea on what could be happening? thanks
I dont think it necessarily HAS to run both ways, its possible the oil can only be mixing into the cooling system or vice versa... Harbor freight sells a leakdown tester for less than $30 that could probably help in diagnosing a gasket issue before you tear it all apart if youre having doubts...
oil in coolant
What i do not understand is why the coolant is not milky looking. Oil in pan is clean on dipstick have not drained oil in pan yet.Will get a leak down tester.When you put pressure to the radiator it should force coolant to the oil pan right?
Do have that but losing oil to the tune of about half qt in 50 miles.It is motor oil it is just as clean as the oil in pan not even mixed or milky looking.
You guys are right on the power steering. It has the in line cooler and the power steering resevoir is low,I can also see a bit of green in it. Any idea were you can get one of the in line coolers or is their another way to go? Still losing alot of oil and it really is not smoking alot for as much oil as it is going through.Trying to talk my self out of pulling the motor back out i guess.
I've prevented this problem before it became a problem on my Firehawk.
Order an upper radiator hose without the P/S cooler built in, part # 10271554
Install it in place of your stock P/S cooler.
Then, go to Advanved Auto and buy an EconoKool Trans-Cooler, part # 242009 and some extra p/s hose, to install the Trans-cooler as your new P/S cooler.
Parts are completely seperate, and no way for one to contaiminate the other.
A small write is here:
http://www.go-fast.org/z28/pscool.html
oil in coolant
I had one other person tell me the same thing that it will use some oil.I am getting the power steering cooler fixed today will change oil and filter and drive with my dad following me to see if and when it is smoking.
