WIll anything read airbag codes?
i opened up the 4 bolts under the steering wheel & found a button with a broken bracket M6 & a hard lanch can break ur clutch switch dunno for A4 but i guess u should start random diagnosis =P
Snap On Solus & red brick, Autoengineuity or an OTC Nemesis will read air bag codes. The Snap On red brick scanner can be had for fairly cheap on ebay. An OBD2 scanner like at auotzone will only read engine codes. Even if you could pull the codes you would need some good service info & the knowledge to find & fix the problem.
Ive got a "brick" but the cartridge only goes to 01 and this is an 02.
Maybe I can convince my buddy to let me use his black cartridge.
I have service info but would like to find out where problem is to start looking for a bad connection.I have AutoTap(wont do airbag or VATS) and a superchips Max microtuner
