ASA cam is in. 'with idle vid"
finally got it put together.
stock 98 short block with 241 heads, ASA camshaft, LS7 lifters, N-motion timing set, yank SS3600 stall, 3.73's , full BMR rear suspension , pace setter longtubes and ORY, TSP rumbler cat back.
it obviously needs a tune, but this is the second time firing it up. have to button a few things up to make it drivable. hopefully ill get it tuned soon and make a few passes in with and see how it goes.
http://www.youtube.com/watch?v=jgTHvR27bQw
thanks bro.
GMPP ASA Cam
226/236 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
110 LSA 107ICL
well its all buttoned up and i put 20 miles on it today. the stock tune doesnt like rpm's under 2000. it bucks and surges a little bit, but i expected that. on the highway it runs flawless and pulls like an animal. im takin it easy til i get it tuned. but it sounds great pulls good ( for the couple times i nailed it.) the YANK SS3600 helps a lot. i dropped the tha hammer from a 5-10 mph roll a couple times and it just spun the tires thru 3 gears til i let off. the torque is definately there.
none as long you do it right and have a good set of stands. the car doesnt move at all. take your time , make sure the weight of the car is spread evenly on the stands and the stands are under a heavy part of the frame rails.
i hear ya sharpe, theres some ASA haters out there. thanks for the compliment.
its all about reliabilty and power, its a proven set up. ls6 yellow springs and stock everything else. make tons of torque and no worries about valvetrain breaking.
open header video...first start up. forgot to post this earlier.
http://www.youtube.com/watch?v=MdtzP_Igq7U
That's why I was thinking about running that cam in my set-up. It's made by GM, proven and easy on valve train parts, not to mention, it has a naaaaaasty-*** idle! I just wonder if it will pass the sniffer test, as I am in California and have to smog my vehicle every other year...
