View Poll Results: Which intake would you run with this set up??
FAST 90/90
23
85.19%
LS6
4
14.81%
Voters: 27. You may not vote on this poll
Which one would you run??
I've got a Patrick G EPS spec cam on the way and I'm stuck between swapping on a Fast 90/90 I have laying around or continue running the LS6. My only reasons for parting with the Fast would be for the $$$. The cam is a 226/230 .598/.600 114LSA. Would the gains with the Fast be worth it? These things are so much money that I'm having a hard time convincing myself the extra power is worth it...HELP ME DECIDE
you already have the fast, and it's only worth a couple hundred more than the ls6
so for $200-250 you get 15-20rwhp now and room to grow later...that's 3-4 times the gain of an underdrive pulley which is the same price with new belts
no brainer
but yes the Fast 90mm tb sucks...get ready to do some sanding to stop it from hanging once its installed...doesn't hang off the intake but once installed it does, or at least that was my issue, after you stop the hanging its good to go
sell the ls6 and tb for $350 or so and call it good
no brainer
