LT Headers: Am I good to go?
I am about to purchase a set of LT headers with catted y-pipe. I understand that I also need to get the 02 extensions. I do not have AIR or EGR on my car right now but I would like to run cats with the new setup. Is it true that the life of my cats will be shortened due to the !AIR? Also, is there anything else I need for this install besides the 3 things mentioned above? Do new header gaskets usually come with a new set of headers? Thanks for the help.
you arent gonna hurt your cats with no AIR, but get the race headers so there isnt any hook-ups for the AIR on the new pipes, I just got done doing my headers about 2 hours ago, not too hard of an install just takes lots of cigarettes beer and time haha good luck
Did you install your headers with a lift? I am wondering if it is worth the trouble installing them with the car on jackstands.
I did it on jack stands. Just get the car really high up and it helps a ton if you have someone to help you. The hardest part for me was getting the drivers side header up there.
just had to remove the plugs and wires, obviously, and i did them on jack stands, had the front stands all the way up sitting on 2x6's stacked and had to put the rear end up on stands to get a good angle to get the passenger side header in place, the headers wernt that hard to install, buy the TSP y-pipe that i bought wouldnt bolt up, so im headed to the exhaust shop tomorrow to get it fabbed in
the way its turning out im probly gonna have to scrap the TSP and get a compleatly different mid pipe
He means:
http://www.arp-bolts.com/catalog/Cat...atalog049.html
Don't forget to redo your engine mounts while you're at it...
