Cleaning pistons still in the block. What do you use?
Old 08-31-2010, 12:58 PM
Rob94hawk's Avatar
Default Cleaning pistons still in the block. What do you use?
What do you recommend for cleaning the carbon off the pistons still in the block? What cleaner and how you do it. Figured I'd get some oil down the cylinders, get the pistons at the top, then clean them. Thanx
Old 08-31-2010, 01:15 PM
Village Troll
SS RRR's Avatar
Brake clean and a wire brush. Works marvelous.
Old 08-31-2010, 01:17 PM
95z28onjuice's Avatar
combustion cleeaner works great and no scrub
Old 08-31-2010, 01:20 PM
WS Sick's Avatar
Make sure you get all the junk that gets down by the piston to the first ring.
Old 08-31-2010, 03:02 PM
Wicked94Z's Avatar
carb cleaner worked better than brake clean for me when i cleaned up my heads since it doesnt evaporate so fast. you could always just mist water in the intake tract every so often to keep the carbon buildup to a minimum, or leaky headgaskets work great, or maybe shell nitrogen enriched gasoline
Old 08-31-2010, 03:23 PM
WYATT318MOPAR's Avatar
Castrol Superclean is some bad stuff, it eats everything
Old 08-31-2010, 08:15 PM
93v8clone's Avatar
a good healthy shot of nitrous ..........................................
Old 08-31-2010, 08:31 PM
mean_greenZ's Avatar
LMAO!! works every time
Old 08-31-2010, 10:34 PM
noice's Avatar
I use carb cleaner from the local parts store, I tried the CRC Brake Clean and it didn't work all that well. The carb clean and a rag were all I needed to make the pistons shine. I didn't worry about the side of the piston down to the top compression ring.
After I was done I coated the cylinders lightly with motor oil.
Old 09-01-2010, 12:40 PM
razor02097's Avatar
I don't use anything metallic... When I decarbonized the bike I bottomed 2 of the cylinders and fill it with yamaha parts cleaner mixed with fuel. then the other 2 got soaked with penetrating lube. Drew out the cleaner from the 2 cylinders, switched to the other 2 and let them soak.
I was able to wipe off the fouling with a paper towel. Used a scotch brite to remove any tough spots and brake cleaner to get out the last of the junk.
Old 09-01-2010, 01:15 PM
AChotrod's Avatar
Sand blast them. lol JK!
Old 09-01-2010, 03:06 PM
fergymoto's Avatar
If you want to save some time cleaning pistons scrape the top with a razor blade, then use a solvent and wire brush.
Old 09-01-2010, 04:57 PM
Village Troll
SS RRR's Avatar
Mineral Spirits works well too.
Old 09-01-2010, 05:14 PM
Wicked94Z's Avatar
Carbon on the piston tops isn't necessarily a bad thing... Baked on carbon functions like a "free" heat barrier coating. However if there are large uneven deposits it'll cause hot spots which can cause pre ignition. A local well known builder has sworn off of heat barrier coatings and now just glass beads piston tops to help the carbon form an even "coating."
Old 09-01-2010, 05:23 PM
speed_demon24's Avatar
Gasket remover melted it right off for me, but I wouldn't mess with it unless there's a ton of it baked on there.
Old 09-01-2010, 05:43 PM
l 95 Trans Am l's Avatar
You made my day
Quick Reply: Cleaning pistons still in the block. What do you use?
