Temp sensor?
If the resistance/temp value of the GM sensor is the same as the aftermarket sensor you should be able to use it. You would have to do some research to determine that, though.
Good info here.
I am doing an LS swap into my '96 and want to keep all the gauges in my original cluster functional for a seamless integration.
Good info here.
Not sure but here's an old post with the 98 resistance/temp values.
https://ls1tech.com/forums/conversio...auge-59-a.html
