Anybody a Mac Whiz?
Old 09-03-2010, 12:05 PM
Domsz06's Avatar
Default Anybody a Mac Whiz?
So my mac book pro used to be super fast, but now it's slower then dirt.
I have tried clearing the cache, internet cookies, and files.
still slow, it has 4 gig of ram and the 2.3 processor. Anyone have any ideas or things to try to make it faster? Or does anyone work on them on the side... Pay you cash or beer... more if you actually fix it lol
Thanks.
Old 09-03-2010, 05:24 PM
twitchtwice's Avatar
macs dont have the same problem as windows computers where it slows down. id say it may have a hard drive issue or something else going on. still have the 1year warranty on it?
Old 09-03-2010, 05:54 PM
westtexasbuff's Avatar
The "slowness" that occurs, is this just sometimes, or all the time? Is it "slow" to browse the web, or "slow" to open up a program...? If it's slow to browse the web, then it might be your internet connection. If it's slow to open up programs and such, I'd look into just building yourself a custom pc. There's do it yourself kits on newegg for cheap.
Old 09-03-2010, 06:30 PM
00fastta's Avatar
They shouldn't go slow. They are highly optimized machines. As said before is it just the programs, internet, or both?
Old 09-03-2010, 08:03 PM
Morbid's Avatar
That's a bit of a drastic step just because it's running slower than it used to.
If this were a Windows machine you were speaking about then I would first look into things that start up automatically with the PC. Then check the services that are running or run at start up. Disable things that don't need to start every time you reboot. The clean up the PC of unused applications/addons/files/etc.
Some of this may still apply to Macs, I don't know, never use them.
Old 09-03-2010, 08:13 PM
scss02's Avatar
There are a lot of reasons a mac can run slow. What OS are you running? You might need to reload your OS. You could also can go online and find free software to clean up ALL cache (not just the cache from the internet). Could be a corrupt program. Have you run your disc utility yet (thats the first thing I would do).
Macs tech support are also very helpful even if its out of warranty
Old 09-03-2010, 08:49 PM
LS1powered09's Avatar
reload OS on it and if you still having the same problem, it could be a bad hard drive or bad memory dimm. good luck!
Old 09-04-2010, 11:25 AM
Domsz06's Avatar
thanks guys, i'll try these ideas.
It's all the time, open programs, internet, start up and shut down etc...
Old 09-04-2010, 11:47 AM
Bash's Avatar
Reload the os.
Old 09-05-2010, 02:02 AM
00'BlueSS's Avatar
Try this...it will repair system errors. You can do this every 3-4 months just as a precaution or as needed...
Restart your computer. As soon as the apple screen appears, hold down the apple key and 'S' to go into single user mode. It will take you to a black screen with a bunch of writing on it and your cursor will be at the bottom.
Enter: /sbin/fsck (space) -fy and hit enter. It will run system checks for a few minutes. When completed, it will either say 'file system was modified' if an error was found and corrected or file system ok. Then just reboot as normal.
Hope it helps! Good Luck!
Old 09-13-2010, 06:14 PM
Domsz06's Avatar
Well I tried that and it checked out ok 00'bluess
See how it runs...
