Help with heads !!
Help with heads !!
I put on TSP PRC Stage 1.0 LS6 CNC Ported Heads and only gained 10 WRHP
WTF !?!? I know here is more HP but where ?
I have233in 239ex 595 605 lift cam,Slp LT,LM1,S2TB,3600 stall, LS6 intake,SLP CAI, On 1998 Trans Am WS6
HELP!!!
HELP!!!
LS1Tech Premium Sponsor
Need more specs on that camshaft to start. And I agree, if you haven't already retuned, do so. Do you have a before/after graph from the same dyno and same/similar weather conditions?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I think they are asking for the specific cam specs. (all specs including what lobes its cut on and where it came from) Also, details about your first dyno, and details about your second or after dyno. My questions-->>>And how experienced is the tuner? All other mods done to the car. Help us help you.
I'd set AFR's so they read 12.7:1 @ WOT and start @ 25* of timing flat @ WOT from 2800rpm on up to redline. Use that as a safe baseline pull (watch for KR). Add in 2* and do another pull (watch for KR). If more power was made and no KR, add in 2* more and do another pull (watch for KR). I wouldn't go past 30* of timing. You'll see where the sweet spot is when it stops making power - don't just keep adding until you see KR. My bet is you'll find best numbers around 28*. If you see KR, it'll most likely appear between 4500~5500rpm.
That's an impossibility. Something else is wrong with the combo causing the low numbers.
__________________
OP: Did you have any luck getting us a dyno graph for before/after? Any chance they locked the stall for the before and dyno'd it unlocked for the after?
__________________
KR = Knock retard - the PCM will pull timing if the knock sensors detect detonation in the motor.
Timing might be too high causing you to lose power. Just because a motor can take extra timing doesn't mean you should run that much. I'd be curious to see the numbers around 27 or 28 degrees of timing.
