Help with heads !!
WTF !?!? I know here is more HP but where ?
I have233in 239ex 595 605 lift cam,Slp LT,LM1,S2TB,3600 stall, LS6 intake,SLP CAI, On 1998 Trans Am WS6
HELP!!! Last edited by erickprouty; Sep 14, 2010 at 05:08 PM.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Timing might be too high causing you to lose power. Just because a motor can take extra timing doesn't mean you should run that much. I'd be curious to see the numbers around 27 or 28 degrees of timing.
