pilot bearing??
Old 09-15-2010, 09:19 PM
00 black ss's Avatar
Default pilot bearing??
i just finished up my build and bringing it to my tuner to fix some problems i am having and finish up my car. question is the pilot bearing already installed on my new crank? i know for a fact i didnt install one. but i know i didnt take it off my old setup. im not entirely sure where it actually is? can someone help me out
Old 09-15-2010, 10:48 PM
LS-1Z28's Avatar
Here's the pilot bearing:
http://www.camaros.org/images/bellho...le_Bearing.jpg
It is located in the back of the crank. The end of your transmission input shaft rests inside this pilot bearing.
Did you replace or reinstall the clutch? Usually, an alignment tool is placed into the pilot bearing to hold the clutch disc in place until the pressure plate is installed.. Without your pilot bearing you would not have been able to use this tool.
Old 09-16-2010, 08:18 PM
i installed a new monster. do they come on new cranks? i bought a compstar 4.00 crank.
Old 09-16-2010, 09:08 PM
bigj2717's Avatar
No you have to install it in the crank
Old 09-19-2010, 02:39 AM
TDP
TDP's Avatar
He is right, you have to install it yourself. When you purchase a new crank, they have no way of knowing if its going with an Auto or manual trans. It's available at any local auto parts store. Part number L381.
Old 09-19-2010, 09:51 AM
alright thanks guys. does anybody know how many hours it will take a shop to install one? im trying to get an estimate of how much it will cost me
Old 09-19-2010, 09:59 AM
ghostbird's Avatar
probably a few hours if they know what they r doing
Old 09-19-2010, 12:16 PM
Arc00TA's Avatar
Did you drive the car with no pilot bearing in there?
Old 09-19-2010, 02:22 PM
no my car is getting towed there
Old 09-19-2010, 05:02 PM
TDP
TDP's Avatar
Most shops charge anywhere from $200-$400 labor.
Quick Reply: pilot bearing??
