Will a bigger cam make that much more?
Right now i have a custom AI grind 230/236 on a 112LSA and i was thinking of going bigger to make more power. I can spin my bottom end to 7000rpm and right now the rev limiter is at 6500.
I made 405rwhp thru my current setup. Any suggestions on what I can do to have it make more? I'm not sure it would be worth the money but just checking..
What he said^, You have to consider driveability, we had customers go to a larger cam, driveability became a little harsh on everday street driving and they only gained just like AI said, some 8 some 10 HP...But to some people, this is not a concern and will do the mod for the extra 8 HP...
You're not getting the potential out of the cam you have, so don't change it. I have slightly less cam than you, same heads and am spinning it to 7000, still making more power there than in the next gear. 425 SAE rwhp. If you're running AI's recommended valvetrain, then just raise the limiter.
The best track time i got was 12.00 @ 121 and that was spinning the crap out of the drag radials. No matter what i cant get the thing to hook...I got so pissed that i revved it to 6000 and dumped it and broke the torque arm the last time lol. I have the borla cat-back right now, not sure if i want to go True duals or not. last time i asked that question i got really mixed reviews..
Thanks -- I'll raise the limiter now and see if that will help...but I still don't know about running a 100 shot on rings that werent gapped properly..
