Volvo Hits the Dyno
Old 09-23-2010, 01:24 PM
Nashty's Avatar
Default Volvo Hits the Dyno
View My Video
Although you can barely see it, that's a Volvo Duett there with a magnacharged 5.3 that's essentially stock except for a smallish cam.
First run boost started at 9 and dropped to 5. There it made 380hp and 447 ft/lbs.
Changed belt during dinner. Then Boost started at 9 and dropped to 7 where it made 425hp and 488 ft/lbs.
That would indicate if I get the belt slippage worked out, it should make around ~470 hp and over 500 ft/lbs. (woulda-coulda-shoulda). Honestly, I don't care, it's more than enough power for a street car.
Old 09-23-2010, 01:30 PM
chevyboy91188's Avatar
nice coil setup that looks sweet
Old 09-23-2010, 01:42 PM
MYSTIC-1SC's Avatar
very cool ride.
Old 09-23-2010, 02:10 PM
Hugger Z's Avatar
That thing looks cool! Very nice!
Old 09-23-2010, 07:52 PM
S10xGN's Avatar
Nice work as always, Roger!
Old 09-23-2010, 08:10 PM
tonytone4143's Avatar
i like it!!
Old 09-23-2010, 10:37 PM
Nashty's Avatar
First off - BIG THANKS to Randy @ YatesEFI.com
Second - Jim @ Speed Inc. can't say enough, he made the car scream.
Third but not least - Russ, thanks for the shots and being a good guy.
http://www.youtube.com/watch?v=D7BHwVeBSdI&feature=channel
http://www.youtube.com/watch?v=CnsNXhlcvhY&feature=channel
http://www.youtube.com/watch?v=4klDsD2V37w&feature=channel
http://www.youtube.com/watch?v=Xa-v__HTWm8&feature=channel
Old 09-24-2010, 06:57 AM
gofastwclass's Avatar
I dig that! Very nice work. Did Randy build it for you? The work is very nice from the angles I see. I would love to see more pictures.
Is everything running off the same belt? You may try one of those non-spring-loaded belt tensioners if that's the case. I know you aren't trying to get the last bit of power but I'm more concerned with throwing the belt miles from nowhere.
Old 09-24-2010, 09:54 AM
Nashty's Avatar
Randy did the wiring harness and helped with some key decisions, he knows his stuff.
The thing is with those fixed tensioners is they don't move once the belt starts to stretch under load. If you look at the spring loaded tensioner, it relaxes a bit when you hit the throttle. If the belt is stretching, which I would imagine it is since it's rubber and fabric, the fixed tensioner would be counter productive. Just my opinion though.
Old 09-24-2010, 10:01 AM
Chicago TDP's Avatar
Where in IL are you located??
Old 09-24-2010, 12:11 PM
MeanYellowZ's Avatar
This is one of those awesome, well-engineered cars with more neat/ trick/ custom-made items popping up everywhere you look. Thanks for letting me take it for a spin, the power is awesome and the sound is unreal. You sir, are my hero!
Old 09-24-2010, 08:26 PM
Yes he does, more people should give him credit - I know I wouldn't be where I am with these engines without talking to him.
I dig that, but you may be able to use that to your advantage since that is exactly what is "wrong" with the spring loaded type. It's just an idea and I've never had one so I can't say it will work or not. I have a squealing AC compressor that a bit more tension would resolve (I can ever so lightly add tension with a 15mm wrench and the squeal goes away). I've been meaning to buy one for that car as an experiment but I haven't done it yet - too many other projects.
Old 09-25-2010, 11:04 AM
Nashty's Avatar
I live about half an hour east of the Quad Cities.
Old 09-25-2010, 02:11 PM
TierAngst's Avatar
I love how quiet those maggies are. Can't wait to put mine on, been sitting in the box for months now. Sweet ride!
Old 09-26-2010, 11:07 AM
bonecrrusher's Avatar
Quad Sh*tties... LOL... I lived there for 4 years... glad I moved away... haha.
I love the engine and blower combo!
You should check out the Power Tour - that thing would fit in with a few magnacharged LS swaps on it, plus the tour seams to go thru IL every year!
Quick Reply: Volvo Hits the Dyno
