Block clearancing?
Old 09-27-2010, 12:45 AM
ThorsLT1's Avatar
Default Block clearancing?
does the block need to be clearanced for a 383 setup? If so how much would a machine shop charge?
Old 09-27-2010, 01:45 AM
fex77k's Avatar
I had it done for 500 cash (balanced, cam bearings installed, cleaned, bored, decked, and clearanced).
Old 09-27-2010, 05:39 PM
ThorsLT1's Avatar
what about the oil pan do you have to get an aftermarket pan?
Old 09-27-2010, 05:44 PM
Fazz73jr's Avatar
I had to dent in one of my pan rails just a hair on my stock pan. The Eagle h beams I used in my 383 have bolts that hang pretty low. So to answer your question no. Just may have to BFH it a little.
Old 09-27-2010, 11:19 PM
brucer's Avatar
local machone shop here charges $120 to clearance the block on a cnc mill.
Old 09-28-2010, 11:24 AM
fex77k's Avatar
I ran an aftermarket pan for the extra oil not the clearance so I can't tell you if it fit.
Old 09-28-2010, 12:14 PM
qc97z's Avatar
^^ X 2. Stock pan can be used and will clear, just a bit of pan rail adjustment may be needed.
Old 09-28-2010, 12:21 PM
Puck's Avatar
It really depends on your rods and rod bolts how much clearance work needs to be done.
My Eagle H-beams would not have needed as much as they did if I went with standard rod bolts or ARP-2000s over the massive L-19s.
Old 09-28-2010, 03:58 PM
hitmanws6's Avatar
Not sure what it was to clearance my block but for the magnaflux, hottank, boring .030 over and clearancing for a 383 was 500 bucks
Quick Reply: Block clearancing?
