Speedinc. fuel line mod. Simple swap?
Old 09-27-2010, 06:54 PM
Rob94hawk's Avatar
Default Speedinc. fuel line mod. Simple swap?
Looking into these fuel lines to clean up the engine bay but as I'm looking at the pic I notice that there is only 2 fuel lines but when I look in the engine bay there are 3. Is one line eliminated? Are 2 the return line and 1 goes to the fuel rails? What am I missing here?
http://www.speedinc.com/cont.cfm?cid=C0001018
Old 09-27-2010, 06:56 PM
OlMastaScrilla's Avatar
The third line is for evap you can delete it fairly easily.
Old 09-27-2010, 06:58 PM
SoxXpupPeT's Avatar
correct. The swap is easy. I made up my own kit, but its just like speed incs. It makes the engine bay look 100x better IMO
Old 09-27-2010, 06:59 PM
AChotrod's Avatar
yep^^ Pretty simple job hardest part is deciding where to drill the holes.
Old 09-27-2010, 07:06 PM
Rob94hawk's Avatar
Thanx. I"ll have to check that out. I haven't looked that far back yet. Been concentrating on the front end of the car these past 2 months. lol
Old 09-27-2010, 07:10 PM
AChotrod's Avatar
Youll see it all when installing the kit. I just put a filter on the end of the evaps hard line under the car.
Old 09-27-2010, 10:31 PM
Big bird55's Avatar
ach could you take pictures of the fuel lien relocation done to your car and where ou had to drill at thanks
Old 09-27-2010, 10:39 PM
AChotrod's Avatar
yup.
Old 09-28-2010, 09:01 AM
TheTransporter69's Avatar
Got any pics or part number of the filter? im thinking about doing this as well, did doing that throw a code also?
Old 09-28-2010, 11:14 AM
AChotrod's Avatar
if you take off the evap it will throw a code and the filter I used was just a small spector cone filter from autozone. Just popped it on the end of the hardline under the car.
Old 09-28-2010, 06:25 PM
LethalZ's Avatar
that looks very clean...what kinda of valve cover are the ones on your car really like them.
Old 09-28-2010, 06:36 PM
nice i might add that to my to do list for winter mods
Old 09-28-2010, 10:49 PM
Rob94hawk's Avatar
Nice! I'm guessing I can get those grommets at any autopart store?
Old 09-29-2010, 12:00 AM
Rob94hawk's Avatar
Trying to google the crap out of that right now cause I'm not getting it. I'm sure once I see it I'll figure it out.
Old 09-29-2010, 12:05 AM
ThorsLT1's Avatar
any gains with it?
Old 09-29-2010, 12:07 AM
Rob94hawk-It goes through the inner fender well on the driver side, you can cut it off right in there (a black plastic piece holds in all the lines) and put a filter on it. Or do what i did and follow it all the way back to the tank and put the filter on back there. But trust me when you get the inner fender out it becomes very obvious.
ThorsLT1- There are no proven power gains that i have ever heard of, it mearly burns off gases that build up inside the tank.
Old 09-29-2010, 12:13 AM
MattSapp95_T/A's Avatar
Yes they are pretty common.....Just go in and look in the "help" section..... I cut one big hole when I did mine....Either way works fine....
Yea once you get under the car to take the old lines off you with have 2 lines with actual clips 1 is a fuel pressure side and the other is a return....the 3rd line which is the evap will have a plastic union ...separate the hard line from the stock plastic line and put a little cheap filter on it..... Very simple...
Originally Posted by ThorsLT1
any gains with it?
No I don't think you will see any gains with it....Just look MUCH nicer then those hideous factors lines....and there is no risk of them becoming pinched or brittle like the factory line....
Matt
Quick Reply: Speedinc. fuel line mod. Simple swap?
