Need engine advice
Need engine advice
Ok so for what ever reason my ls1 decided it wanted a new window and apparently the pistons tried to escape out this window. Now I think it seems as though its cheaper to go the lq4 short block route. Does any one know(assuming the heads are still good) if cartek stage 3 ported heads would work with this set up? Also what else would I need to do in order to run this set up? Thanks alot and sorry for the newbish question.
A lot of guys just use two bolts and get by fine. IIRC there is a boss on the block where it goes though.
For boost an LQ4 would be best because the pistons are dished to drop compression... If you are going to build it get whatever is cheapest because the blocks are the same... but LQ4's are usually cheaper..
