Anybody using a PowrMAF 103.5mm Mass Air Flow sensor?
I was just browsing Tick, and:
http://www.tick-performance.com/cata...induction/#maf
I've found some smatterings here and there mentioning the PowrMAF, but not too much info on it. I would think that if you're going to use a FAST 102/102 setup, this would be the best MAF to use to make sure there is no restriction.
However, a huge maf with no screen would make me worry about the stability of the air readings it takes. If I'm gonna run a MAF instead of going with a maf-less speed density setup, I'd want to be damn sure the maf is taking accurate readings.
Just in case you're wondering, I would not do this for a bolt-on only car. I'm preparing for a future head/cam swap by doing everything on the intake/exhaust side first.
Tick Performance now proudly offers the largest MAF available on the market which also boasts the lowest resistance of any MAF on the market! Made of Nylon 66 material, this impact resistant monster utilizes the stock LS7 or LS3 Hitachi MAF meter, and has a OEM style receiver for the o-ring gasket for a perfect seal. Marine grade stainless steel allen screws and washers come with this MAF, along with a plug-and-play harness that allows you to install this unit directly into your LS1 F-Body!
I havn't used one just wanted to add my 2 cents. I have a 85mm truck maf on my car which was fine when I was running with a H/C setup. With the bigger cubes the maf ran out of calibration when we were tuning also the manifold was pulling vacum which we felt was of the restriction of the maf. I am seriously considering running mafless next year simply because the car ran much better without the maf when we were dialing in the tune. When I asked the tuner he said that the cats and maf aren't capable of adjusting for the amount of air and exhaust that the car is producing.
PowrMAF
I have the PowrMAF with a screen, I am in the process of tuning the MAF sometime within a week from now. So I am still in SD mode at the moment.
It is HIGHLY recommended that you install a screen to clean up the airflow, which inturn cleans up the signal for our PCM's.
there is tons of posts on HPTuners website in the forms section about 100mm+ MAF's and the difference the screen makes to signal.
f-bodys have a very short path to the throttle body, so... a nice clean signal will make tuning easier.
the only issue i can relay is the IAT sensor will be about 15% off, I believe HPTuners is already working on getting us this fix, and I have read that the beta version already has the ability to scale the IAT correctly.
lastly it is a GM MAF sensor, in a composite housing which includes the pigtail to adapt to almost every LSX based vehicle.
-Trev
-Trev
Oh yes I know, you should tune for any MAF. I'd even tune a ported stock or descreened maf (although I would never descreen any MAF, and I will add a screen to this one)
That is actually the exact setup I have in mind. The only thing I can't decide on is if I want to do those big ram airs like the chrs1313 or not. We'll need some good heads and a cam to take advantage of all that flow potential
How did you all attach the screen to the inside of the MAF? Looks like you can now buy a 100mm precut honeycomb screen: http://www.saxonpc.com/100mm-cells-for-100.html
I run a PowrMaf 100mm with a 4 inch downtube on my 427 w/ FAST 102. I used one of these:
To be honest, I didn't notice any real difference. Ed Hutchings at VA Speed does my tuning and he didn't have any problems without it but I wanted to try it anyways. I took it out for a track day and it may stay out.
Just my $.02
Just my $.02
Just my $.02
Just my $.02
Moderator
If I were youse I wouldn't use the in-MAF IAT anyway;
anywhere underhood the heatsoak is a nuisance. A
thermistor with the right curve would set you back a
buck or two at Digi-Key and you can put it wherever
you want.
you want.
LS1Tech Editor
Sorry for the rookie question, just trying to sort all of this out. I've decided I'd like to stick with a MAF since it's my DD, just trying to sort out what's my best bet.
Moderator
I've tried about all the permutations and am happiest with the IAT up in
the cowl air vent where it reads outside air. Though this would probably
be the wrong idea for a boosted speed density car, it makes a good deal
of sense for a cold air NA setup especially at the big end, and let trimming
deal with any low end error.
