Alternator Wire Gauge?
Old 10-07-2010, 09:42 PM
gMAG's Avatar
Default Alternator Wire Gauge?
The original wire gauge on my 67 Camaro is 10. I reused this gauge and connected it to the LS1 alternator. While the alternator is the lower output model, it still produces more amperage than the stock 67.
More recently, I decided to reuse the orig LS1 battery cables and noticed that the LS1 alternator wire looks to be much larger...like about 6GA.
Is the 10GA wire safe/acceptable for the LS1 application?
Old 10-07-2010, 10:03 PM
knievel's Avatar
This is a good chart to use
Old 10-07-2010, 10:24 PM
gMAG's Avatar
Just what I was looking for. It looks like the 10GA isn't gonna cut it.
Thanks very much!
Old 10-07-2010, 10:25 PM
Speedy911's Avatar
I use 4ga for alternator charge cables.
Old 10-07-2010, 10:46 PM
gMAG's Avatar
I'm wondering what GA I have...6 or 4? Anyone know what size comes with a 98 alternator?
From the looks of it, the LS1 cable will take the short/direct route rather than all the way around the nose, as the 67 did.
Old 10-08-2010, 09:14 PM
chevyboy91188's Avatar
i think the factory short pigtail is usually 8ga or at least that what it was on the silverado one i got
Old 10-09-2010, 09:41 AM
FastKat's Avatar
I have taken wires off of a variety of late model GM vehicles with alternators ranging from 102 amps and up... they use 6 gauge wire. The later model vehicles use a smaller "fusible link" wire on one end (about 6 inches long) to protect against shorts, etc.
Old 10-10-2010, 06:30 AM
samdogmx's Avatar
i used 2g but my battery is in the trunk
Old 10-10-2010, 11:02 AM
gMAG's Avatar
Thanks all!
After cutting the prev mentioned 67 stock 10 ga, I decided to reuse the factory batt/alt wires and chose one of the red 4? GA.
Now I might have another issue which I will pose in another post....
Quick Reply: Alternator Wire Gauge?
