LS1 build
LS1 build
hay guy's i'm trying to build a 500 to 600 hp ls1 for my drift car. i currently have the stock motor in my 95 nissan 240sx. i came up with a list and here is what i was thinking of using
parts.
eagles 383ci stroker kit
world warhawk 235cc heads
cam ? was thinking comp cams XFI cam but world heads spec to use solid roller cam.
fast intake with 90mm + get port.
fuel injectors?
for the cam if anyone can point me to a nice lob cam for high revving thanks and as for fuel injectors ? what would be a good pair, if anyone has info hit me back thanks
parts.
fuel injectors?
From a previous experiance .. the following setup put down 530rwhp via A4 car
- Trick Flow 215cc Heads
- Custom Stroker Cam by Speedinc
- 383cid End Bottom ( Diamond Pistons 3.905" flat-top -2 / Callies Rods 6.125" / Callies Crankshaft )
- Total Engine Airflow Ported Victor Jr
- 4 barrel TB with scoop ..
get a fast 102mm intake and TB.use a fuel injector calculator for the injector size,contact FIC.prc 227,or afr 225/235,or tfs 235.get a cam from Patrick-G.search for a 383 build by Tony Mamo of afr.
