High Lift vs. non High Lift cam?
Can someone educate me on the pros of running the F14 high lift cam over the non high lift F14. I'm not sure what the additional lift will do in terms of power/torque, but I assume it would increase it. I would also like to know if the F14 high lift cam will have less P/V clearence than the non high lift F14.
whts the benefit from a short duration high lift cam?
like the torquer V3 231/234 .643"/.598" vs the MS4. 239/242, .649"/.609" almost same lift but dif duration..
sorry for the thread hijack
Duration is basically "how long" the valve is opened. The higher the duration #, the longer the valve stays open. Which does affect PtV clearence.
Either way, gains will be minimal at best, I would assume, and might affect the powerband, but thats its.
Honestly, I dont know. I would either contact FUTRAL, or Ed at Flowtech. That guy has endless knowledge of this.
+1.
The same basic cam (duration) but with more lift usually will lower PTV clearance a little because the ramp rates are faster. It may not be proportional to the added lift, however.
The duration, given that valve lift is adequate, will shift your power curve. Adding lift only can beef up a power curve without shifting it in either direction, but can (but not always) make life harder on valve springs, and may reduce total rpm due to earlier valve float. It may cause lifter collapse as well if some of the combo hasn't been thought out well enough.
If you are diligent about checking for worn springs, and spec the whole combo out very well, the higher lift cam can get you power. Most times, however, and especially for mostly street use, the regular or mild cam lifts are a better idea.
short duration cams with big lift generally make more torque. same lift with more duration (when lope center lines are kept the same) will generally make a bit less torque but more hp and it will be higher in the RPM band. is with a high lift and same duration you will gain some torque
sorry, but Lol
stock heads with upgraded spring, stock bottom end,
cam:
.580/.590
288/294
236/242 @ 050
114 lsa
am i running into clearance issues? my car is barely running and im lined up dot to dot.
cam:
.580/.590
288/294
236/242 @ 050
114 lsa
