6.0 to powerglide ???
Old 10-20-2010, 09:36 PM
Rhino83's Avatar
Default 6.0 to powerglide ???
I'm building an 89 camaro with a 6.0 out of and 03 express van it was originally mated to a 4l80e I want to mate it to a powerglide. I've read numerous posts on this as far as using this flywheel or this spacer etc etc.. However I'm still a little confused. On summit when you type in the hughes flywheel number it tells you that you also need there spacer. I need to know what I need as far as a flywheel or spacer I know the two will bolt together no problem.
Old 10-20-2010, 10:08 PM
chevyboy91188's Avatar
if the 6.0 came with the flywheel from the 4l80e it may have the spacer some of them were adapted like that I believe? don't quote me on it though
Old 10-20-2010, 10:09 PM
key4's Avatar
I have a PG mated to my 05 6.0 and my motor came with a spacer on the flywheel and its the factory stuff. Everything went smooth but I think the spacer only came on certain years. Check your flywheel if it has a spacer behind you should be ready. Maybe someone else will chime in that knows what year they started putting the spacers on.
Old 10-20-2010, 10:13 PM
zipster's Avatar
My 02 Lq4 came with the spacer on the flywheel, unfortunately I scrapped it on Monday. Sorry.
Old 10-20-2010, 10:14 PM
Rhino83's Avatar
That would be sweet seeing a new flywheel is $200 plus. Thanks for the quick responses I'll have to check and see if I have the spacer already.
Old 10-21-2010, 12:15 AM
ZTwentyAteU's Avatar
hmmm. we should really find out what years this fw came on
Old 10-21-2010, 07:36 PM
Pocket's Avatar
With the adapter, you use a SBC 1pc RMS flexplate. If you have a 6.0, you have the spacer. Only 99-00 6.0's did not have the spacer, but it was cast into their crankshaft
Old 10-13-2011, 08:45 PM
Rhino83's Avatar
I ended up using the stock flywheel and spacer had to oval the holes to get the tc to bolt up. My problem is I think I still need more of a spacer cause my torque converter is not seating all the way into the pump????
Quick Reply: 6.0 to powerglide ???
