Aluminum PS Pulley
Old 10-27-2010, 03:24 PM
philsblwnz28's Avatar
Default Aluminum PS Pulley
Does anyone have the Aluminum PS pump pulley? If so, are there any drawbacks from it? Mine just cracked and I am looking to get an aluminum one. Thanks
Old 10-27-2010, 05:59 PM
Pocket's Avatar
Got a link? Only alum PS pulleys ive seen are aftermarket. No problems should come from the stock plastic piece unless you bonk it, then its toast. LSx trucks used a steel pulley of the same dimensions which Im running currently
Old 10-27-2010, 10:02 PM
Mike@ZMS's Avatar
I have a Turn-One pulley on my pump.. Works great, no issues and it allows me to access the bolts on the pump without having to pull the pulley off first.
Besides.. It looks cool too.
Old 10-27-2010, 10:58 PM
99'CajunFirehawk157's Avatar
I bought mine from http://store.wazees.com/Category/11-...s-engines.aspx
Have not installed it yet, want to get it anodized.
Old 10-27-2010, 11:00 PM
lemons12's Avatar
I habe a billet pulley, love it. As said, can get to bolts.. holds belt on better.. wont crack.
Old 10-28-2010, 04:22 PM
rabbit320's Avatar
will a lighter pully also free up a hp or 2?
Old 10-28-2010, 04:53 PM
bayer-z28's Avatar
^ Would like know too for numbers..
Mmmmmm... Shiney... I don't think I've seen or even thought abotu stuff like this in a long time..
Old 10-28-2010, 05:58 PM
dutinsss's Avatar
being that the stock pulley's plastic, i doubt an aluminum one would be any weight difference enough to give or take any horsepower. if it was lighter, i can't see it giving you anymore power than what the dyno would fluctuate from run to run.
Old 10-29-2010, 07:41 AM
bayer-z28's Avatar
^ Good point.. Fluctuation and all.. If we had the "other" cars we could say it helps spo0l VtaK.
Old 10-29-2010, 09:36 AM
-TheBandit-'s Avatar
I have a 2010 L99/LS3 P/S pulley. You can get to all three mounting bolts and I'm pretty sure it's steel (seams awfully heavy if it's plastic).
PN 12610794
P/S pump pulley
$40.16list or $24.09 through gmpartsgiant.com or you could probably get it cheaper through gmpartsdirect.com
Old 10-29-2010, 10:39 AM
joecar's Avatar
PN 12610794
P/S pump pulley
Do you have a pic of this pulley...?
Old 10-29-2010, 11:27 AM
Joshiedoom's Avatar
Subscribed.. Turn one also makes a pulley
Old 10-29-2010, 12:00 PM
I can take a pic of mine also if you need it. It felt heavy enough that I'm 90% sure it's steel.
Old 10-29-2010, 12:22 PM
studderin's Avatar
I drilled 2 holes in my plastic LS1 pulley to get to the bolts. use a unibit works great
Old 10-29-2010, 02:11 PM
I just can't see paying $60 for a plastic pulley from GM and then having it break again. SO I think the aluminum one I saw on Ebay might be the ticket. Plus I can get to the bolts.....
Old 10-29-2010, 03:52 PM
The L99 pulley is not plastic, it's only $25, and you can get to all the bolts. What's not to like?
Old 10-30-2010, 01:41 PM
dutinsss's Avatar
i'd go with that if mine broke. but if not, i'd just drill holes in the factory one like studderin said.
Old 10-31-2010, 08:29 PM
stubbs4's Avatar
wait the l99 ps pulley will fit an LS1?
Old 11-03-2010, 02:59 PM
That I couldn't tell you with certainty
