What did you use for block off plates?
Hey fellas an unusual thing happened to me today , put my headers on right , the headers came with the emisson holes , so the qestion is what did you do when you had this problem?
Note: Block off plates don't work theres no thread pattern .
no see the headers i have the egr holes on the headers are bigger than the regulars ones, when I put the old egr plates on they was to to small so I have to try and find a way to get this done.
@ Z28 2002 you cut your heat shield and used that ? No leaks huh?
cut them off and have someone weld a small patch on...I have personally seem 3 snap off before and on all types of headers...pacesetters, qtp, and hookers
check this thread out a few down
https://ls1tech.com/forums/generatio...d-headers.html
