Lifters, rockers, injectors
Old 10-31-2010, 08:34 PM
KL20's Avatar
Default Lifters, rockers, injectors
Want to upgrade these three items. Not due to something wrong, just time to do so. I need opinions on which of each I should go with. Here's what's done to my car now and I'll also say what the future may hold if it makes a difference.
'00 Z28, 130k miles, stock heads, stock bottom end, bolt ons, vig 3600, F1 cam, stock 10 bolt with 3.42's
Possibly have heads within a year, maybe nitrous (150 tops).
I was thinking some LS7 lifters, rockers and injectors I'm not sure on. I'm a budget modder so best bang for the buck.
Old 10-31-2010, 08:41 PM
Fastdriver1992's Avatar
u can find 42lb injectors for 300$ online and rockers aren't necessary to upgrade but if your looking for a high performance direct replacement go with a roller rocker wont give u any more power but will lower friction and heat
http://cgi.ebay.com/ebaymotors/ws/eB...d=290265964152
http://www.summitracing.com/parts/SUM-G6980
Old 10-31-2010, 09:04 PM
KL20's Avatar
Oh I was under the impression that upgraded rockers could free up some hp due to less friction. Guess I won't waste the money for something that I won't see a benefit.
Old 10-31-2010, 09:31 PM
lubelizard's Avatar
Stock rockers with a trunion upgrade has been the standard improved setup for anything except very high lift, high rpm setups.
Old 10-31-2010, 09:36 PM
KL20's Avatar
Any possible gains from the upgraded injectors? Is 42 the best to jump to or is it overkill?
Old 10-31-2010, 10:27 PM
RedHotG8's Avatar
The injectors won't give you any more power unless you are maxing yours out. The lifters and rockers won't give you any more power either.
Old 10-31-2010, 10:56 PM
KL20's Avatar
Well maybe there's no need to do any upgrades. I guess the stockers last and hold up with my mods.
Old 11-01-2010, 07:41 PM
u gotta be making 400rwhp before u need new injectors. and the stock rockers are fine for what your doing. my friends got a giant 650/650 lift cam with the stock rockers so those r very strong, rollers will free up some hp but nothing noticable. if u really want to wake up the car do a cam upgrade with a set of ls6 heads, then you'll start making some noticable hp
Old 11-01-2010, 08:33 PM
RedHotG8's Avatar
He's got a cam but he wants to do new heads.
Old 11-01-2010, 11:33 PM
KL20's Avatar
Most likely I'll just go with some worked LS6 heads, nothing major.
Old 11-02-2010, 11:13 AM
Lambert695's Avatar
with worked heads and a cam you will need different injectors. rwhp really doesn't have much to do with it. its at the crank and with a cam in a 2000 you're probably close to maxing them right now.
Old 11-02-2010, 07:13 PM
KL20's Avatar
which ones should i go with?
Old 11-02-2010, 07:17 PM
Darkman's Avatar
You will, of course, need a tune coincidental with the installation of different injectors.
Old 11-02-2010, 07:42 PM
cadenwade's Avatar
Anything over 42lb will be over kill. I would go with either ford racing 36, 39, or 42 all th ford injectors were tested at 43.5 psi and gm uses 58 psi on theres so that means a 42lb inj well come out to be around 49.5+.
I am running the 42lb in my car and i love them. I also love the fact that i can do more mods and injectors is not something i have to think about.
Old 11-02-2010, 07:43 PM
cadenwade's Avatar
sorry just rambling on..
Old 11-03-2010, 07:46 AM
KL20's Avatar
It's cool, I welcome any and all info. I'm really green when it comes to knowledge of internals.
