Drag Racing Tech
How do you shift for low ET's
Old 02-02-2004, 10:11 PM
newbie_tace02's Avatar
Question How do you shift for low ET's
Have an M6. Usually I try to shift it just before the peak RPM for the car setup I have. But I get very different results depending on HOW it's shifted.
For example, if I do it by letting off the gas while hitting the clutch, and shift at the bottom of the clutch, I get nice RPM curves in EFILive (very consistent shapes). On the other hand, if I wait a little and shift while the clutch is coming back up, the RPM upslopes occur later in the log but occassionally I'll misshift and mash (grind - ouch!) the gears.
I've tried shifting while hitting the clutch and backing off the gas just a little bit (70 - 80%) throttle, not a full throttle release. The car tends to transition from gear to gear faster, but the damn tach jumps around a lot and it becomes hard to tell when it's time to for the next shift. I suspect clutch slip may be what's making the gauge jump around until it "bites".
At least to me, it seems as if the last method provides a more sustained power profile. The shifts feel closer together and the car is kept in a much narrower RPM band, like 4000 - 6000 RPM (if the factory tach isn't lying), but it's harder to nail the exact 6000 RPM spot where I should be shifting...
Anyone care to share your shifting secrets?
Old 02-02-2004, 10:49 PM
Navy David SS's Avatar
First get an after-market tac with shift light. Set it at 6000 (or 6100) on the stock rev limiter of 6150.
On the shifting, why let off the gas at all . Learn to power shift. Without letting off the gas, jam in the clutch and shift all in the same motion. It will take practice, but after a while it is second nature. PRACTICE PRACTICE PRACTICE. Oh forgot, hope you have upgraded your clutch and tranny
David
Old 02-03-2004, 02:20 AM
LSX Mechanic
Damian's Avatar
You don't need to POWERshift to be fast. I completely let off the gas when I shift, and my car sounds like an automatic while WOT...
Just takes practice..
josh
Old 02-03-2004, 10:06 AM
gator's 99TA's Avatar
mine sounds like an automatic as WOT too...
Old 02-04-2004, 07:37 AM
racer88's Avatar
David
I will say get a shift light! They are great.....you don't have a Mustang so you don't need to powershift! Most who have powershifted have torn up tranny's....it's not worth it.
You can be just as fast shifting if you practice.
Old 02-04-2004, 08:02 AM
Hardtop's Avatar
josh
Werd.
Bruce
Old 02-05-2004, 10:26 PM
SMOKIN01TA's Avatar
josh
ditto that
Old 02-05-2004, 11:47 PM
FAST LS1's Avatar
I lift also but shift as fast as humanly possible. I try to shift as close to the limiter as possible on every shift.
Old 02-06-2004, 12:54 PM
SMOKIN01TA's Avatar
i have a video from my car at the shootout if i knew how to just select that section i would send it to you. there is a non noticable amount of drop in the front between shifts and i use the cluch, just fast as hell, after the new clutch i think my left leg doubled in size compared to the right one.
Old 02-06-2004, 04:58 PM
mike c.'s Avatar
summit has a GREAT dile and go shift light. it's $50.00 and fits awsome in front of the factory tac with some velcro. i never lift my foot off the gas when shifting,i've also NEVER had a trans problem in 20,000mi of pure ***** to the wall abuse.
Old 02-07-2004, 05:53 AM
TheMongoose's Avatar
got a part#?
Old 02-07-2004, 09:02 AM
mike c.'s Avatar
yes i do it's (pro-67005c) this is for the black shift light case. they also come in blue pro-67005bc,red pro-67005rc and silver pro-67005sc. it's a didial and go turn the **** to any rpm u want. no pills and can be adj-in odd # rpm's(6,100-6,200,6,300 and so on till 12,000rpm's) $49.88 this is bad azz.
Old 02-07-2004, 09:42 AM
Orange99Z's Avatar
What about a Harlan shift light - red, yellow, green, orange, or blue LED's - adjustable from 500-12,000 for 2,4,6, and 8 cylinders with no pills or modules. It too is only $50 & $5 shipping. The biggest complaint I hear is that it takes a while to get it once it's ordered. Damn, this sounds like an add.
Old 02-07-2004, 10:03 AM
jamnut's Avatar
I've had my Harlan light for almost 2 years. I set it when I first got it and it's never given me a bit of trouble. Never had to be re-programmed or anything. Also I must have been one of the rare ones, I got my light in under 3 weeks & was prepared to wait 2 months for it.
Old 02-08-2004, 12:12 AM
jerflash's Avatar
get a shift light
if you are stock set it to 5800 because by the time you shift to second you will be at 6000. first gear revs fast.
second to third i wait a lil after the light goes on then shift but i listen to the motor also
and third to forth same thing just wait alil longer
and i dont powershift
12.40 @ 112 1.96 60ft(clutch slipin)
lid catback, nitto
12.51@115.5 best mph 1.94 60ft(tires blazin)
oh and i run a raptor shift light better the the harlen anyday
Old 02-08-2004, 07:25 AM
Bob Cosby's Avatar
You can certainly be fast without powershifting - and you'll save parts, too. However, if you want to squeeze the last little bit of ET out of your car, aggressive powershifting (done correctly) will produce the best times.
Old 02-08-2004, 08:10 AM
jerflash's Avatar
i can paoershift and i do it well its just that once powershifting 4th my trans got stcuk in forthgear and it came out and i dont have any problems now but until i have the cash to really beef it up i dont wana break it
