good cam for ls1
good cam for ls1
im looking to just do a cam swap on my 98 trans am ls1. i just had it on the dyno and it made 334rwhp and all i know it has done is long tubes to an xpipe and the computer is tuned and cold air. do those numbers sound right because they say the car in 98 comes with 305 to the motor which should be like 280 to the wheels. im lookin to get 400rwhp. anyone got an good suggestions?
A 228/228 cam would probably be pretty good for ya. It all depends on what you want. Call one of the sponser here on the board and tell them what you want. You could even go with a custom grind.
I'd say with a decent cam an good components and an LS6 lid u can hit the 380+ range.
Yeah, those are pretty good numbers that you are putting down. I just read your other thread about wanting to go with a bigger cam.. So, I would really call one of the sponsers on here so they can get you all taken care of. Good luck.
There is a wide variety of camshafts you really can go with to get you close to that goal or even surpass it. It depends on what you want for street manners, what you are willing to do gear wise, etc. PM me or call me at the shop and we can definitely point you in the right direction for a camshaft.
There are a gazillion "good" cam choices. Which one is right for you depends on many things. I recommend putting some thought into your long term goals, budget for the next few years, and then doing some research since there is a new "what cam is right for me" thread every day, and has been for years. Once you narrow it down and provide more info you will get more useful advice.
Captain Double Post
Call texas speed ,there very helpful and are great to deal with,just tell them what your looking for outta your car,there are a lot of cams to go with and a lot of good sponsers on here,I know when ever I have delt with tsp they have always taken care of me,there prices are pretty good also,good luck with your cam search,I agree a stickey should be made ,there is like 5 post at the moment that say (cam choice 400 hp ) lol,God bless
Captain Double Post
Agree with Davex,you have to do a lil more research on this,and give us a lil more info,there are a million cams that will get you 400 hp,but you do wanna get something that will work well with future mods if you plans are to add on,rearend and gears,heads,spray etc, is this gonna be a dd,weekend /race car?these are all things you wanna think about before picking one,also where do you want the cam to start making power?
Captain Double Post
I just saw your other post about a big cam,if you go that way,no matter how good your tune is you can get some surging and a lil bucking at low rpms,more or less depending on how good your tune is,I run a ms4 in my m6 and it runs really good but we put a lot of time into the tune,3 hours of dyno time and a few on the street,only bucks a very lil at low rpms and the surging isn't to bad,but I suggest if you go big also do rod bolts,I'm gonna do mine over the winter so its all set for next year,I also plan on running 4.30 gears or higher,I love the ms4 but depending on your goals for 400 it is overkill,there are a lot better street cams that will give ya a better power band,I also went with the ms4 because I wanted to spray,hope some of this info helps,but call a few sponsers and talk with them and get some ideas going on what your looking for
well its my daily driver. and once i hit 400 im done. no nitrous or anything else. i drag race a 10.50 car so i dont need to make it a racecar. just wanna make my street car a little bit quciker.
After reading your current mods that are done to the car, I don't think a 222/226 or a 226/230 ish cam will get you to 400rwh. I hit exactly 400rwh with full bolt ons, ported TB, TB Bypass, LS6 manifold, and a EPS 226/230 cam through 4.10's. You might need to look into a couple more mods to get you to 400. I wouldn't go putting in a BIG cam either being it's your DD. After driving my 226/230, I personally wouldn't go bigger then a 228/230 or a 230/234 for a daily driver.
Stock hand ported 5.3 heads, 228r, longtubes, ory, magnaflow, fast intake and tb netted me 409rwhp with great street manners, recently upgraded to torquer v2 power is now 422rwhp. Only slight surging with the new cam.
