Transmission...what parts to get
Old 11-27-2010, 05:19 PM
DieselPump's Avatar
Default Transmission...what parts to get
Over the winter, I plan on gathering a bunch of parts for my tranny and then taking it in to get it rebuilt
So far, I have a trans-go shift kit and a trans cooler on the car.
I've bought a new hardened 4th clutch shaft, and a low mileage 4340 input shaft.
Also on the list are:
7/8" chain with 3.29 gears
new torque converter
TEP Master kit with zpak 3rd
sonnax sure cure kit
I've been looking at a zzp output shaft, either solid or gun drilled. Is this needed?
Also, a chrome moly pump shaft. Once again is this needed?
Mods are headers, rockers, 3" exhaust, tune. I'll have a ported TB and LS1 intake, g8 maf and 4" intake pipes on by then as well.
Thanks for the help guys.
Old 11-27-2010, 05:54 PM
2005gxp's Avatar
im also looking into this stuff. but ill build it myself and save the labour lol
Old 11-30-2010, 10:20 AM
DieselPump's Avatar
Bump for guys that have done their transmissions!
Old 11-30-2010, 01:16 PM
LS1 Racing's Avatar
Are you getting the TEP valve body, as well? If not, it's worth the $300. It should prevent most of the issues our transmissions seem to have. I'm waiting on mine and should have it this week.
Old 11-30-2010, 02:58 PM
DieselPump's Avatar
Thanks for the recommendation, I'll add that to my list.
When I order the upgraded valve body, can I cross off the sonnax sure cure kit off my list, as it seems those parts are what goes into the valve body?
Old 11-30-2010, 04:48 PM
LS1 Racing's Avatar
I'm pretty sure most of the Sonnax kit goes into the TEP-massaged valve body.
Also, make sure to get the Sonnax Converter Relief Valve, if not's already included. It costs about $5.00 and will keep your TCC from grenading. and wiping out your trans.
Old 11-30-2010, 04:55 PM
DieselPump's Avatar
Awesome, thanks.
I'll be sure to add that to my order.
Old 11-30-2010, 05:23 PM
Ill_Born_ss's Avatar
http://www.sonnax.com/part_finder.ph..._only_sc=false
also they have some new stuff for just us, I`ll see if I can post it somehow.
edit; just contactthem they are great to deal with and will set you in the right direction, fyi they don`t sellto the public but will set you up with someone real close to you.
Quick Reply: Transmission...what parts to get
