408 stroker
Old 11-28-2010, 02:15 AM
ss408truck's Avatar
Default 408 stroker
People that are running turbo charged 408 strikers what size cam r you'll running i am having a problem picking the cam for my setup I
Have a 00 trans am that I am going to be turbo charging my motor is 9.4 to 1 compression I have a afr 225 heads and 102 fast intake and throttle body I plan on running anywhere from 8 to 15 psi.
Old 11-28-2010, 04:13 AM
bww3588's Avatar
i can understand why your having a problem picking a cam, you have a problem picking words and putting them together to form an understandable sentence.
anyways, a custom cam would be your best bet.
Old 11-28-2010, 04:49 AM
F-BodyMind's Avatar
Damn.. No need to criticize, we all know what he ment. This isn't english class. But yeah I would go with a custom grind cam. Call up the sponsors on here, they will guide you in the right direction.
Old 11-28-2010, 05:38 AM
bww3588's Avatar
your right, its not english class, therefore i shouldnt have to diagram a sentance to understand what is going on.
Old 11-28-2010, 07:04 AM
Mr.4mulabird's Avatar
i understood what he was saying just fine. Then i again i am a genius
and +1 on custom grind cam
Old 11-29-2010, 01:18 PM
freakyfastlsx's Avatar
call cam motion they will help you
Old 11-29-2010, 01:25 PM
Hemi2Slo's Avatar
Looks like it was typed from a phone. Which can be aggravating. Might wanna check your own before you criticize too much. Anyway, custom grind is the only way to go in this situation.
Old 11-30-2010, 08:09 PM
nodrok's Avatar
THAT IS THE FUNNIEST THING IVE EVER HEARD ON LS1TECH.
How ever i went with a custom grind on my 402 stroker.
Old 11-30-2010, 08:56 PM
09camaro383's Avatar
Im putting together a turbocharge ls3 420 stroker I went with a custom cam these are the specs of my cam 236/236, .602"/.602" 115 LSA I hope my grammar is ok
