problem's shifting in sub freezing temperatures
I own a Cts-v with the t56 and in cold temperatures 32 and below I have difficulty shifting. Being a newbie to manuals I wanna know if this is a normal thing or is it more serious. I also have a bite when shifting into 3rd when the car is cold. Will a short throw shifter eliminate this problem or is something more serious required. Please help granny gurus thanks.
Cold fluid or older fluid. Try some fresh fluid like Royal Purple. My Camaro does that when it's cold out, but not BAD.. Just a little tight. I just hold it in second for a little while to let the R's climb and "throw" more oil around in the transmission so it will help warm it up a little. Not for a WHILE, but I do it for about a mile or two. Seems to help. The oil being squeezed through tight clearances should help it to warm up.
The shifter won't do anything for a gear-specific problem.
Avoid Royal Purple in any case.
Mine does it too. When it's cold out the thing shifts like it's a coffee can stirring rocks. After the car warms up it's fine though. I think it's just what happens when it is cold out. +1 for changing the fluid though. I changed mine back in the summer and it is a lot easier going this winter than it was last winter with the old fluid.
Actually if you let the car warm up even in neutral for a few minutes, it will help with the shifting qualities. I use to have a little Ford Ranger that would actually start to move foward in neutral when it got really cold outside. The gear lube in it was probably thicker than molasses. Shifting it was next to impossible until it warmed up a little bit. I ran gear lube in it to help cover up some of the gear noise in the transmission.
It is normal for manual transmissions to be a little tough to shift in sub freezing temps. I wouldn't worry about it too much. Just take it easy when its cold and shift with care. If you feel it clashing don't force it in.
Why should he avoid royal purple?
Recommended by Tremec? Nope. M1 is.
Whether the blocker ring story about Liberty testing their product holds any weight isn't relevant. There's simply zero gain in going w/ RP. Marketing fluff doesn't shift anything better.
If it helps your bottom line to sell and use RP, that's great.
Shifts are still going to be the same but your shift lever will need to move slightly less. This isn't going to do anything beneficial for the trans.
Synthetic in the T56 in freezing temps? Zero gain at higher cost.
We have seen a lot of overpowered T56 transmissions over the years and the ones using RP had noticeably less damage than transmissions using standard ATF. That is why we recommend RP for high HP cars.
I guess sense you don't build 150+ T56/TR6060 transmissions a year you wouldn't see the gains of Royal Purple over standard ATF. That's fine I don't expect you to. I didn't recommend that he use RP in his application, I was just curious why you told him not to.
I sense your sarcasm. I wasn't trying to say you couldn't comprehend anything. I was simply saying we see a lot of transmission traffic through here so we start to see trends after a while. Transmissions that are simply overpowered with standard ATF end up being completely melted down inside. The input and cluster gears are literally rounded off. Where as the transmissions running RP simply develop noise or wear and chip the teeth.
Cool thanks for the advice. I hate to break stuff in the Cts-v cuz its always so damn expensive. So if y'all say royal purple is out of the picture for Tranny fluid what will top it?
Amsoil Torque Drive. It's full synthetic and helps quite a bit with cold shifting. I put it in my 06 after the first winter with the car. It's still grumpy when it's -10C outside but nothing like the factory fill.
Maybe you need to learn more. ALL manuals have a degraded shift quality when cold. Re-engineering the oil with ANYTHING other than the std ATF is just funny. Get their warranty on cold shifts....Like they really know! Buy all the moose-urine- enriched -mystry -oil you want , if you feel like some one else should have your money, but the std oil is what you should use.
BTW..
BTW..
