Xtreme Transmissions New Year Sale + New 6L80E Converter
Xtreme Performance Transmissions New Year Sale
4L60E Level 2 Transmission $1450 or $2100 with Billet Converter +Free Shipping
Hardened pump rings
Servo D ring kit instead of Teflon
New Accumulator Pistons
Modified Pump Assembly
Oversized Boost Valve
High Quality Overhaul Kit, Frictions and Bushings
Xtreme Transmissions Shift kit
Borg Warner dual cage 29 element Input Sprag
Corvette 2nd gear Servo kit
Wide rear sun gear bushing
Heavy duty sun gear shell The Beast
High energy 2-4 Band
High Energy 7 friction clutch pack with full thickness Kolene Steels
Teflon Pump Bushing and Extension Housing Bushing
Built with Performance Tolerances and Lube Modifications
4L60E/4L65E Level 3 Transmission $1825 or $2500 with Billet Converter +Free Shipping
New electronics
Hardened pump rings
4th gear billet servo kit
Billet 2nd gear Servo kit
Upgraded Bearing Type Reaction Carrier Shaft
Wide 2-4 Band with Reinforced Anchor
New 4L65E 5 Pinion OEM Front and Rear Planetary Set
High Energy 8 friction clutch pack with full thickness Kolene Steels
Input drum Steel sleeve prevents input drum breakage at spline area
Teflon Pump Bushing
2-3 Shift Valve Upgrade
4L80E Level 2 Transmission $2395 Or $3150 with Billet Converter +Free Shipping
4L80-E up to 800HP
Completely Rebuild with Quality Rebuild kit
High-energy Performance frictions
Bonded pistons
34 element intermediate sprag
Xtreme Transmissions shift kit
New solenoids
New OEM Filter
New sprags
New Trans-go Spacer plate
New speed sensors
6 Direct frictions instead of 5
HD Int. Snap Ring
Billet Forward Hub
No core needed
4L80E Level 3 Transmission $2800 Or $3500 with Billet Converter +Free Shipping
4L80-E up to 1000HP
Bonded pistons
New solenoids
New OEM Filter
New sprags
New speed sensors
HD Int. Snap Ring
Billet Forward Hub
300M Input Shaft
300M Intermediate Shaft
No core needed
TH400 Street/Strip Transmission $875 or $1150 with High Stall Converter +Free Shipping
6L80E and 6L90E Performance Rebuild -- CALL
TH400 Race Transmission with Trans-Brake $1395
6L80E Billet Converter any stall (2800-4000) $785+Free Shipping
4L60E Billet Converter any stall (2800-4000) $695+Free Shipping
4L60E Deep Cast Aluminum Pan $135
TH400 Deep Cast Aluminum Pan $95
4L60E 300M Input Shaft $339
4L60E 300M Output Shaft $445
6L80E 4340 Intermediate Shaft $650
4L80E 300M Input Shaft $320
LS1 OEM Flexplate $55
LT1 OEM Flexplate $49
No Core Needed on any of Transmissions on sale
If you have any questions Contact Johnny@ 310-714-3869
http://xtremetransmissions.com
Hardened pump rings
New electronics
Hardened pump rings
Teflon Pump Bushing
4L80-E up to 800HP
Bonded pistons
New solenoids
New OEM Filter
New sprags
New speed sensors
HD Int. Snap Ring
Billet Forward Hub
No core needed
4L80-E up to 1000HP
Bonded pistons
New solenoids
New OEM Filter
New sprags
New speed sensors
HD Int. Snap Ring
Billet Forward Hub
300M Input Shaft
No core needed
i am definitely looking for a new trans, have been looking at performabuilt. i've never heard of these guys, can someone vouch at all for them??? like the price though, $500+ shy of any other offering with the 5-pinion upgrade. this is going into a 2wd truck
https://ls1tech.com/forums/western-m...year-sale.html
https://ls1tech.com/forums/western-m...sion-shop.html
https://ls1tech.com/forums/western-m...smissions.html
https://ls1tech.com/forums/automatic...sion-sale.html
So, is this sale still on? And, what is the difference between the $1450 sale price in this thread and the one here: http://www.autopartsfirm.com/catalog...products_id=32 I was under the impression that that was your site, but it was a different price than advertised here. Just wondering...
Scott
Scott
Yes the sale is still on. It is the same. They are one of my distributors. In the end it will be the same price because I have included the shipping in this post and they have not.
Transmissions come with one year warranty if buy just the transmission or 2 year warranty if you buy a trans an converter combo the warranty is still good even if you are racing full time. If you are buying a race transmission then the warranty should cover you if you race.
