Are my flat top pistons really flat?
Old 12-19-2010, 01:49 AM
tnmotown's Avatar
Default Are my flat top pistons really flat?
Ok I bought a rotating assembly from TSP for my 408 and ordered the set of Wiseco pistons PN#K464X3. Now it says -3cc for the piston but when I had it done at the machine shop they said it seems more like a dome top piston and pops up more like +5cc. Im just trying to figure out the right size so I can make a selection on which heads to use.
Thanks for any input!
Here are the pics, p.s. don't mind the writing its an inside joke.
Old 12-19-2010, 03:27 PM
tnmotown's Avatar
anybody??
Old 12-19-2010, 03:54 PM
Darkman's Avatar
For what it is worth, some vendors are listing the K464X3 as a reverse dome piston as opposed to a flat top piston.
Edit: additional The Wiesco listing does not appear to provide any particular description http://www.wiseco.com/Catalogs/Automotive/Chevrolet.pdf
Old 12-19-2010, 04:34 PM
tnmotown's Avatar
I'm not too familiar with inverted dome, would that mean its a positive cc then?
Old 12-19-2010, 04:58 PM
Darkman's Avatar
No, it does not mean positve cc, but its appearance may be different. Specifically, if the machine shop was expecting a piston that looked like a stock flat top piston with "fly cuts", the Wiesco K464X3 may not look like that. (Since online pictures are often generic, I cannot find a reliable photo of your piston.) It may look like a slightly dome pistions with reliefs "mashed" into it. Simply put, the confusion may be one of appearance .
Old 12-19-2010, 05:20 PM
tnmotown's Avatar
I'll try and take a pic of it. It definately has two little bumps above deck. The numbers on the pistons say 6464X3 also.
Old 12-19-2010, 08:07 PM
tnmotown's Avatar
pics added
Old 12-19-2010, 08:38 PM
Darkman's Avatar
pics added
The Wiseco catalog uses the term "Flat Top" for some of the other pistions, but not for those in this LS stroker series. Other vendors call it a "reverse dome" as I said earlier. Presumably the effect of the valve reliefs and the added material just opposite nets to -3cc specification.
Old 12-19-2010, 08:42 PM
Nemesis350's Avatar
Not sure about the first part he said, but the rest sounds about right considering what the pistons look like in the pic.
Old 12-19-2010, 08:55 PM
tnmotown's Avatar
Ok I get what your saying, so in reality these ARE -3cc pistons then?
Old 12-19-2010, 09:04 PM
Darkman's Avatar
I thiink they are based the part number, the Wiseco literature, and your pictures. But I'm just a stranger on the internet - by all means give TSP a call to verify it before you put it together.
Old 12-20-2010, 09:10 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
It's a flat-top as stated on your invoice. Wiseco uses that "hump" on the other side of the valve relief for a couple reasons. One reason is that you get a deeper relief without having a large negative volume (because the hump is positive volume to offset some of that).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-22-2010, 02:59 AM
tnmotown's Avatar
Gotcha, I called you today just to confirm on everything. Looks like they are what they say they are lol. Thanks for the help you guys and now I can decide on which head to go with. Oh, TSP maybe you can hook me up on a deal for some nice heads
Old 12-22-2010, 09:24 AM
We've got a big cylinder head sale going on right now!!
__________________
Old 12-22-2010, 12:32 PM
PowerShift408's Avatar
What kind of price can you give me on a set of PRC 237s?
Old 12-22-2010, 01:15 PM
Fully assembled with the PRC .675" lift EHT spring kit they are $2149.99 plus shipping! Sale is good through Monday morning, January 3rd, 20111 at 9am Central time!
__________________
Old 12-22-2010, 02:40 PM
PM sent.
Old 06-22-2019, 06:24 PM
Tomcat1962's Avatar
Default I have the 6464x3 pistons
These pistons are in a engine I bought I'm trying to find out what they are any help would be appreciated thanks
Old 06-23-2019, 10:43 AM
LLLosingit's Avatar
Plenty of info in this post and a simple search shows they still sell the same piston. http://www.summitracing.com/parts/wis-k464x3
The following users liked this post:
Tomcat1962 (06-23-2019)
Quick Reply: Are my flat top pistons really flat?
