MS4 w/ Patriot Stage 3 heads???????
Ive started on my new build and trying to decide exactly how I want everything and I am looking for some input on the heads. Before I get to far, I am on a limited budget and most likely will be going with Patriot or PRC heads, leaning more toward Patriot for the fact that I live about 20 mins from their shop. Here is what ive got so far, Im keeping stock CI, Scat H-beam rods w/ Mahle Piston w/ -4cc valve reliefs, and a MS4 camshaft specs are 239/242 .649/ .609 111LSA, I was considering the Patriot Stage 3 Heads, but Ive read where some people say its to big of a head for stock CI, here are the specs on these heads if not familiar with it:
Combustion Chamber: 64cc
Intake Runner: 227cc
Exhaust Runner: 70cc
Intake Valve: 2.08"
Exhaust Valve: 1.60"
Max. Valve Spring Lift: 0.650"
Spring Pressure Closed: 135 lbs. @ 1.800"
Spring Pressure Open: 375 lbs. @ 1.090"
Retainer Material: Titanium
Valve Seal Material: Viton
Valve Guide Material: Manganese Bronze
Valve Job: 5-angle
There site says they flow 320intake @ .600 and 235exhaust @ 600. Would this head be wrong for my setup?? Thanks
Intake Valve: 2.08"
Valve Job: 5-angle
the prc 227s that TSP likes to put on the MS4s have 227/84cc runner, i dont see why the stage 3 wouldnt work as long as they are the right bore size and clear the pistons (after cutting)
IMO opinion your setup sounds great for them. What inatke would you top it off with? The stage 3 sound a lot like the prc 227s and every setup ive seen that was ms4/227 has ran like a raped ape, but they also had ported fasts on top. Not saying a normal 92/92 or even 102/102 wouldnt be good, but i think a LS6 intake would hinder perfemance just because of not being able to get enough air in
i was kinda of afraid of that too but for now its going to be a ls6 intake till i get some more cash saved up, my funds are starting to get thin with as much as ive already got
LS1Tech Premium Sponsor
You'll definitely have to flycut your pistons for that combo! If you're interested in a head that does not require cutting piston,s I would consider the PRC Stage 1 LS6's or the PRC 227's (same as on our record holder car in my sig)! We have a $150 off special for the LS6's and $250 off the aftermarket casting 227's right now!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I would go with the 227s from Tsp. Might as well go with a winning/proven combo. There are some patriot/ms4 combos but i think you would be much happier with either the tsp 215s or the tsp 227.
Go Patriots For the price you can't beat them! Cam only I put down 366/341 and then later added my Patriot Stage 2 5.3's & LS6 intake and put down 417/375. I paid $600 for my Patriot heads almost brand new unassembled and for that price I'd say they are a pretty good head!
