Band clamps vs 3-bolt flanges?
I'm wondering which is a better overall way to hold an exhaust together where it needs to be removable. I looked into the 3-bolt flanges for true duals to attach the x-pipe to the headers, but found these band clamps.
After looking at it, it seems like an expanded pipe over the collector and a band clamp would flow better and probably weigh less/be less work than a 3-bolt flange?
Three bolt flanges will leak after a while also but they are better then the band clamps IMO. If I were to be removing it a lot the 3 bolt is the way to go. The band clamps will stretch out after a while and lose their tension if you take them on and off a lot. Not to mention that even if they are pretty tight they will still let the pipe slide out, that wont happen with the 3 bolt flange. But on the downside the 3 bolt flange will reduce ground clearance a bit..
The ground clearance is one of my main concerns with the true duals. I guess I won't be taking the exahust off and on much, just need the ability to take it apart from the headers. I'll probably have to go with the band clamps since I can't get the welder out to the ramp to weld the first 3-bolt flange onto the headers Forgot that it's too far out in the back yard and the welder won't work on 2 extension cords.
I have both band clamps and a three bolt flange joint in my exhaust system. Both seem to work well. I have had the band clamp off numberous times and it's still tight. No welding with the band clamps. If their is a chance it could pull out either from vibration or acceleration then the flange might be a better choice.
i use a three bolt flange. i had problems with blowing out paper gaskets with this setup. i stepped the gaskets up to some metal percys and i havn't had any problems since. it is very easy to remove my entire exhaust, that's what i love about them. 10 minutes under the car and it's off
I believe you'll find that band clamps work better for pipes that are butted together (same size pipe). And I wish they made them with about an inch or two longer on the one end to better encompass the pipe (hard to explain) Don't laugh I tried The top one would be a normal band clamp the bottom one is my version
You should get some ball and cone two bolt flanges. i have them on my collectors and after my X. no gaskets, no leaking. Look on Dr. Gas's website. They aren't that expensive either.
LSxGuy widda 9sec Mustang
Originally Posted by 02bluess
Ok, I'll bite What's a v-clamp??
I've seen them as low as $35 a set, and sometimes as much as $80. They work well on cars where your changing stuff up all the time.
SN95 Director
Originally Posted by -Joseph-
http://www.secureperformanceorder.co...ProductID=6942
Originally Posted by jrp
so is welding required since it says "Kit includes two weld-on v-clamp rings and stainless stell v-band clamp" or are they two seperate clampss
I'm using a V-band clamp between my Y-pipe and I-pipe. Works great and makes removal easy.
Burns also sells a V-band kit - they're pricey, but they are stainless: http://www.burnsstainless.com/Hardwa...ps/clamps.html
there clamps are pricey but, there X and Y pipes look like nice pieces
Yes welding is necessary. The kit comes with 1 clamp and 2 flanges, enough to connect one pipe to another pipe.
